No upgrade, no downgrade
Hi all
Using Flex 6500 , and Win10.
I was using v2.6.something and wanted tio upgrade to V 2.7.6. It did not work, in the sense that the waterfall shows nothing. I tried to downgrade, and this did not work either.
as a test, I wwas monitoring FT8 : the decode works, abut again, no waterfall at all.
Where should I look ?
Tnaks + 73
Paul F6EXV
Welcome!
  • Member ✭✭
    Trying to be smart, I uninstalled SmartSDR, made sure the .net was up-to-date, reinstalled SmartSDR (version 2.7.6, manually uninstalled and reinstalled SmartSDR CAT, reboot the computer, crossed my fingers... and... and... and... still no waterfall !
    I am desperate.
    Can someone help ??
  • Member ✭✭
  • Member, Super Elmer Moderator
    Hi Paul, have you tried a factory reset? If not, export your profiles, reset, then re-import.
  • Member ✭✭
    I read I should file a help ticket before doing the factory reset.
    I still van use the radio while waiting for the answer.
    Thanks + 73
    Paul
  • Member ✭✭✭✭
    Hi Paul
    A lot of times no waterfall is caused by a Network issue
    Did you do a HARD reset of the radio?
    If you export your profiles DO NOT export the "Preferences" because a lot of problems that flair up resides in the "Preferences" part of the Export/Import.
    if all else fails then YES do a help desk ticket.
  • Member ✭✭
    Hi Paul!
    I hope you are well. I think you have paused the waterfall, try clicking on top of "LIVE" just on the right upper part of the waterfall.
    73! Jon EA2W
  • Member ✭✭
    Your description of No Waterfall is not very specific, the following thread discusses the solution for a Windows bug that causes this problem, but it is not related to the version of SSDR it is a Windows GPU driver issue.
    Ted, WR4T
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    I think you have a waterfall, but your display settings may be wrong.
    Under Black - make sure Auto is selected.
  • Member ✭✭
    Problem solved, it was a disoplay settings issue.
    Thanks to the Help desk for prompt and efficient reply.
    Paul F6EXV
