Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
FRStack Version 3.1.3.7 Released - Stream Deck support
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 89 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 70 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 557 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 155 Power Genius Products
- 120 Power Genius XL Amplifier
- 12 Power Genius Utility
- 23 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 90 Remote Operation (SmartLink)
- 50 Contesting
- 131 Peripherals & Station Integration
- 63 Amateur Radio Interests
- 406 Third-Party Software
Some new ideas and suggestions:
- The Help has an typo in the Active Slice Commands description
http://localhost:13522/api/AciveSlice/{cmd}?param={val} (must be ActiveSlice)
- Add a function to ActiveSlice/STEP to have the step cycling between the defined range, this can save 1 button.
- Same as above but for ActiveSlice/FILTER
73, Max
If so email it to me at the FRStack Help menu support contact. Thanks.
Custom: Rest Call
URL: http://localhost:13522/api/Radio/globalprofile
ClickParam: param=40M
I do have a 40M profile but when I push the button I get no response. Would someone please point me in the right direction...thanks in advance for any assistance.
Regards,
Ronald/W4RJF
Regards,
Ronald
Ronald
So big thanks to you Mark, and I am hopeful it will continue to evolve.
Just purchased an SPE 2KFA.
Mark I have been running DDUTil with a Genovation keypad, love it.
Do you think I should be able to run DDUTil and the Genovation along with FRStack and the Stream Deck without issue?
I honestly did not know about the Stream Deck until this past weekend at SMCFEST in Bloomington IL. WT2P gave a program about his remote setup where he had mentioned this cool new Stream Deck tool he's using. I learned something new, now I want one!
Clay N9IO
I have both the Genovation and Stream Deck working side by side.
DDUtil offers its own CAT commands which I have some of them implemented.
I’ve just taken delivery of my Stream Deck and spent the evening playing around with it, making several errors in the process. It’s a learning curve and I suspect I’ll have further questions as issues arise. Great toy and once I've finally cracked it I'm sure it will become even more useful.
Just a question for now: I want to select just the MIC and BAL inputs (not LINE or ACC, which I don’t use). How do I explicitly select these?
Jeff – G4IUA
That function doesn't seem to be implemented. I'm sure Mark will look at it.
GET URL: http://localhost:13522/api/Radio/MICPROFILE
ClickParam: param=PR-40 Rag
where my MIC Profile PR-40 Rag is using the balance input
I'm sure it's very obvious once you know but I'm still in the very early learning stage!
Now might be a good time to grab the V3 Software users guide an look in the manual. Check out section 16.1 - Mic Profiles and let me know if the helps you some to figure out Mic profiles.
Mike gave you the highlights to get started though.
Jeff
DONE
Jeff - G4IUA
