Hercules MIDI with 6300
191011121315»
  • W4WHL
    W4WHL Member ✭✭
    edited July 2016
  • DH2ID
    DH2ID Member ✭✭✭
    edited December 2016
    William, I like Nrs. 1-4, the program seems to work. Will test it later.
    Because I use ONLY external tuners for all my TRX, I would like
    TUNE to stay fixed. Now I need two key clicks, shift and tune.
    Thank you for your improvements!
    BTW can you tell me the approximate size of the PL-1 compared to the
    CMD micro? I have to fit it to my (small) shack ;-)
    73, Alex DH2ID
  • W4WHL
    W4WHL Member ✭✭
    edited July 2016
  • W4WHL
    W4WHL Member ✭✭
    edited July 2016
    Alex,  I can make a custom version for you to swap them.  Or I can teach you how.  If you like the newest version, let me know and I will compile you a version with "tune" hard coded.
    The PL1 is huge - I would say ~ 12" x 6"
  • DH2ID
    DH2ID Member ✭✭✭
    YES yes yes, hard coded sounds good to me :-) But only if it's not too much extra work for you, you do enough for us!
    Ok, the PL-1 is not for me, then, too big....
  • Bob W7KWS
    Bob W7KWS Member
    edited July 2015
    Quick test before lunch.  More when I get back this afternoon.
    I swapped A & B knobs and that works great.
    I can't tell if the touch sensitivity is playing a part or not but the gear shift in 2.0d seems flawless after a 1 minute of testing.  More later.  Thanks again.
    Bob
  • Steve Cook
    Steve Cook Member ✭✭
    edited January 2016
    William Silly question.  I installed ver 2_0d.  I get the display and it finds my flex 6500 but I get no response.  I have restarted CMD and smart SDR no change.  Any thoughts?
  • W4WHL
    W4WHL Member ✭✭
    edited July 2016
    Steve,
    The drivers are not being installed for the CMD Micro.  My first guess would be your security software.
    Check device manager for any issues.  A few people had similar issues, and it was virus scan software.
    Use an external midi tester such as http://forum.djuced.com/files/p_download/137/miditest.exe to troubleshooting.
    William
  • Steve Cook
    edited January 2016
    Got the problem solved rebooted.  I guess the driver software did not get fully install the first time.  Looks like everything is working great.  Thanks for your hard work on this.
  • jan
    jan Member ✭✭
    > @W4WHL said:
    > I made another small update, the main screen now displays VFO frequencies.  I thought it would be nice to have some visual feedback the program is doing something.
    > (Image)
    > Here is the updated download;
    > https://www.dropbox.com/s/re9tlop8r7y7wje/FlexMidiTCP.zip?dl=0
    no download in dropbox
  • jan
    jan Member ✭✭
    i try to download files from dropbox but it,s dont do it :(
  • Does anyone have an updated version, I just purchase a NEW CMD micro and running a Flex-6500 with version 3.2.39 software...would love to began to play with it...my email: w4jcwjohn@gmail.com
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    edited February 2022
    This is an old thread, but wondering has anyone successfully got a Hercules DJ Control to work with any Flex 6000 series. I have the Hercules DJ Controller Compact version. There are a few dead drop box links for other controllers so I'm hoping someone out there has a solution or can point me in the right direction.
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    i MAY be able to help; i use mine all the time....i THINK there are two versions, one for 32 and one for 64 bit versions of windows...
    drop me a note to w5xz@att.net....73, w5xz, dan
  • Steve W6SDM
    Steve W6SDM Member ✭✭✭
    Yes, I got one working and used it for years. I found it especially useful in contesting and working DX where the operator was working split. I used the software that the author wrote for it. I don't use it presently because I have a Flex controller that does pretty much what I need and I was short of desk space. I'm using a Flex 6300.
  • Mike VE3CKO
    That's good news, looking forward to getting this going, my email is ve3cko@interpc.ca
  • Mike VE3CKO
    Thanks to Dan I've got some files installed but this is for the CMDMicroController. The pop image of the CMDMicro does appear and I do see the mode and fequency for A and B slice in the TuneA and TuneB areas, but that's it.
    Following this thread from the beginning and there was some mention of getting Hercules DJControl to work. I mentioned earlier the dropbox links are dead.
    Looking for FlexMidiTCP.pde so I can at least get the channel, notes etc. for each button. Saying that I can get the mapping of the buttons from Thetis for the Anan as it has midi controller built-in so I can use the Manage Mappings to get all the control ID, names, type and value for the buttons, knobs and wheels. I hope someone out there has a solution without have to reinvent the wheel from the beginning again.
    Any further assistance to get the Hercules DJControl Compact working with 6xxx radio would be appreciated.
