Any update on Tuner Genius?
Hi - I was recently told that the Beta units were modified and sent out to the testers. I suggest you email them directly for the current status. I know they are working hard to get them ready for production.
I am curious who told you that. Was it from Flex or 4O3A? The only info I have been able to get the last 6 months was from the 4O3A group and that was like pulling teeth. I have reached out to Flex multiple times about the status and have never had a return email so I'm not doing that anymore.
Flex would have been better served if they would have made a deal with a company like Palistar. And have them do some simple communications mods, like have USB DRIVERS to run with Flex. It would not have have taken 3 years. Could have been ready quickly with some commitment. I could be wrong, but those that made a deal for the free tuner may never see it. I was one of those, but ditched the deal and bought another brand, which included built in tuner. For give me here for being a devil’s advocate as I do like Flex very much, but they may have bitten off more then they could chew.....
Don't worry, I have been to the factory just couple of days ago. I cannot share any specifics but it is on the way...
Regards
Volker
I am still waiting for the free tuner. I have held off buying one. I have seen a picture of it so it looks like there is a least a prototype. Hopefully the 3 1/2 year wait will be worth it.1
Well, good luck....! In my case I just lost confidence in this situation, time and money rule and I’m not getting any younger. And there was two specs on the tuner that changed my mind in the end. It’s not a wide range tuner and number of switched ports.
Understood. I waited for the amp and I am extremely pleased with it. It was worth the wait. The tuner looks just like the amp, but smaller. I don't know if pictures can be posted on the new forum but a friend texted me a picture of the tuner that was posted on Facebook and it looks great. Just hoping it comes out soon.1
Thanks for the heads up Burch! I found the pic on Facebook – looks like it was just posted.
More grist for the mill!
Howard
Still waiting on my free tuner too. I have a Palstar and an LDG (that I use with the PGXL), all wire antennas here. I would really like to integrate tuner/amp/rig.
Studying the photo, it's interesting that the TG software seems to imply that it now has two inputs (A & B) verses the one that was initially talked about. These inputs appear to be independent from the outputs on the PGXL and this would be a major improvement over what was initially proposed!
Any speculation on what the three disks are in the software with values of 12, 4, 8? Are these related to the three antenna outputs rumored or could these be values in a CLC network?
Bill AB7AA
Hi Bill, SO2R 2in 2out.
Volker
Thanks Volker! That's welcome input!
Any idea about the disks?
Bill, AB7AA
I wasn't expecting such a big box on the Tuner.
Ian0 -
Hi Bill, I missed the tuner by one day, so I did not habe a Chance to Look at it, only some parts of it. But it is related to tuning I would assume.
Volker
It's blurry, but the 12, 4, and 8 appear to be values of C1/L1/C3 respectively, and can possibly be manually set via the knobs underneath the display.
The dual A/B in- and out-ports are an unexpected but very welcome feature!!!
Howard
What you see may not be the finished product. Or, it might. :)
@Mike-VA3MW Or could it be one of a family of potential products? (That is my outsider's bet.)
Steve K9ZW
Sorry Mike, could not resists 😋
"What you see may not be the finished product. Or, it might. :) " - What you see may not ship in 2021. Or it might . :)
Sergey
Sergey
You know the company policy! :)
Seriously, once we have something to share on the TGXL and shipping, we will share it. Unfortunately there is nothing I can share at the moment.
rather funny that no one mentioned this, in that picture they are not using a Flex to drive the amp and the tuner. :-) It looks like an older Yaesu rig. I mean, SERIOUSLY!? The work station is labeled Final Calibration and Test, like a factory position, and they are not "driving their own car"? :-) (My FLex 6600 mops the floor with THAT rig...)
HELLO? Flex Marketing Dept: Pull this thread, and re-stage a proper photo using ALL Flex products in your final test station. :-)
-1 -
@Neal Pollack, N6YFM - The picture came from 4o3a is not a FlexRadio picture or location..
As the 4o3a team has a raft of radios they have displaced from their contest station, so it isn't surprising that an off-cast would end up as a bench-mule.
Likely the 4o3a team will test with every radio combination they have on hand throughout the development process.
Steve K9ZW
Just a few comments:
- FlexRadio will absolutely honor the original agreement to provide the Tuner Genius to those that are owed one based on when they bought the Power Genius amplifier. It has taken longer than we wanted, but like the amplifier, we are confident that it will be worth the wait as we are holding to the same high standards. We understand the anticipation and frustration with the timing. We're right there with you. We appreciate your patience while we work with 4O3A to deliver on our promises with a product that will make you and us proud.
- The Tuner Genius does indeed support SO2R similar to the Power Genius (2x In, 2x Out).
- Steady progress continues to be made on the Tuner Genius. We will make announcements when it is ready.
11 -
Thanks Eric
... it's interesting that the TG software seems to imply that it now has two inputs (A & B) verses the one that was initially talked about. These inputs appear to be independent from the outputs on the PGXL and this would be a major improvement over what was initially proposed!
Reference above. It looks like the TG Utility is showing both the 160M and 20M bands (on its ports A and B). I'm wondering if the TG will be able to handle two auto-tuned circuits at the same time?
KF4HR
Any news here guys on if it will ship this year?
Peter
Peter
Peter - I asked this question on the 403A Forum 4 months ago. This was their response:
..., thanks for your interest in TGXL.
At this point we cannot give any specific date.
Unfortunately, as you know, there are global issues beyond our control.
We work very **** it, and it is almost around the corner. Dragan, 4O4A
Butch
KF4HR
If you’ll read the list just previous, I already answered the question.
-1 -
Mack, are the TG units being built in the US or by 403A in Montenegro?
Butch, KF4HR
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
