FRStack Version 3.1.3.7 Released - Stream Deck support
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you watch FRStack at the same time, you can see that the audio levels change, so the Stream Deck is working correctly.
I haven't played with the Audio settings in FRStack, but, from what I see, those buttons only control headphone volume and line out volume and I think that is on the Radio only.
I'm testing on a remote Maestro and the audio levels do not change. I think this is how it is designed, but maybe Mark can comment.
If you check the FRStack Rest Help, you can see a list of commands.
No its not changing anywhere. Any ClickParam that isn't a numerical value isn't working.
From your web browser if you were to type:
http://localhost:13522/api/ActiveSlice/nblevel?param=UP
It returns:
<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">20</string>
Currently my NB was set for 20
http://localhost:13522/api/ActiveSlice/nblevel?param=30
It returns:
<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">30</string>
Now my NB level is 30 and the key on the Stream Deck updates and says 30
UP/DOWN/FM/DIGL etc type parameters don't seem to be working for me. Am I missing some other windows component(s) or software to support those types of values?0 -
On home screen, 3rd button along top is Slice folder. In this folder is Audio up and down. Here is screenshots of Streamdeck app. These were defaults and they work. One press of up takes the speaker level up by 10. One press off down takes it down by 10. Keep pressing for more level adjust. Hope this helps
One thing to note though, on right side +Slice and button under Slice with strike thru, doesnt work for me. I just get a ding sound, not sure why.
They don't work for some reason on my setup. Hopefully Mark can help explain why.0
Yes that will work. I did supply a profile for the 15 button model so I don't know how that will load but the ability to create a profile will work fine.0
Wayne,
The +Slice and -Slice are hotkeys not Rest calls, i will fix this in the next update.
For now the + slice should be URL of http://localhost:13522/api/radio/slice
with the param of "param=CREATE" and - slice param should be "param=DELETE".
Drag a new Rest Call from right to button and overwrite existing. Then set value to above information0 -
KM2C,
Use the FRStack Help menu item for REST Help to make sure the API command you are using supports the value you are trying to set. For example to set FM the command would be http://localhost:13522/api/activeslice/MODE?param=FM
I am using your default FRStack3 Rest profile. If I type that into my browser (radio is in USB mode currently) I get a response of: <string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">USB</string>0
Thanks Mark, I will correct mine. It worked. Now just have to figure out how to create a new panadaptor. lol
Thanks for your efforts0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNote to all
You may notice that the Band window that the 160M band goes to 6M.
To fix this, just edit the button in the Stream Deck GUI and change the Click Param to
param=160
Mike0 -
Stream Deck control for N1MM. This is just a start for N1MM control. It supports SO2R with focus control. Automates allot of common multi key shortcuts into Stream Deck. I will post the profile file on GitHub site once I figure out how. Contact me and I will send it to you. Thanks Joe N3HEE
What a cool toy. I also ordered the 15-button. Couldn't wait so I downloaded and installed the software and executed the FRstack files and even though I do not have the Stream Deck connected yet, I can view and play with the GUI. Reads info from 6700 but doesn't send any info but at least it allows me to play with the GUI and start building my profiles. This is going to be so helpful in the shack because my Maestro is used nightly at my bedside.
I have a very bad habit of leaving dozens upon dozens of windows open on my shack computer which isn't good. 11 instances of Firefox each with between 10 and 35 tabs open, then Thunderbird, Excel, Adobe PDF and so on. This tool and it's one button app setup will perhaps break me of this ridiculous habit and thus freeing us so much resources.
Thanks for the tips on using this device, Michael's post made it straightforward. On the Bands --> XVTR- menu I added some SWL radio buttons using the stations icons:
_..--
k3Tim / 7
I have FRStack ver 3.1.3.7, but I do not have these files in FRStack3 directory.
How can I get them?
I do not have Stream Deck yet, just installed their SW to check it out, but cannot do much as no files there to run
Sergey, KN7K
How does one save the updates?
Select the option to show extensions in Windows Explorer then you will see full names. They are there.0
They automatically save to the profile you modify , you can export the profile to disk so you have a backup you can return to. Use the gear icon or right click on the profile to save it.1
got it, Thank you Mark!0
Thanks Mark, appreciate the help....
Tim0 -
My Stream Deck should arrive today - therefore it would help if someone would please email or put on the www there SDR/Stream deck profiles and save this pure mortal a lot of time TNX de AlanH g8oo0
Alan
It is extremely easy to program this device. You can even drag and drop buttons to other buttons. Piece of cake
I have updated FRStack to version 3.1.4.8. This version addresses the bug with certain functions not working until Spot menu or Hotkeys were turned on. Rest Help menu not opening a 2nd time. Adds SPE Amp support. Update Stream Deck Plugin to support multiple line Prefix and Suffix text. Updates Stream Deck Profile sample. Have Fun.4
Tnx Wayne
The device has not arrived yet so will spend some time playing with it tonight or tomorrow.
Bye for now AlanH.
Mark W3II thanks for the nice changes. One issue I noticed is that when I invoke a CWX memory from the Stream Deck there is no cw sidetone but if I invoke it from the CWX panel in SmartSDR there is sidetone. Is there a different command for each?0
Mark. I can see the Hotkey editor. I created a hotkey but it doesnt seem to work ? When I click on view hotkeys nothing happens ?0
Any plans for a simple SPE 'On' /'OFF' toggle (not operate/standby toggle)?0
Joe, the view, hotkeys menu check enables and disables hotkeys. Use the hotkey sequence you configured in the editor to activate the configured function.
Roy, there is a command to shutoff the SPE but I could not find a command to turn it on. I use the remote on/off signal on the control port of the SPE to remote control the 1.3K on and off.0 -
Mark,
Thank you *very much* for your support of the Stream Deck. It's a great addition to my desktop.
I have one question: how do you get date from the radio to be displayed on the Stream Deck button, eg: Next Slice A(0) or B(1)?
Michael -- KM6LHD0 -
No luck getting hotkeys to work ? Do I need to have something else installed to use hotkeys with FRStack ?0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
