FRStack Version 3.1.3.7 Released - Stream Deck support
Mark_W3II
Member ✭✭✭
Radio versions starting with SSDR 2.5.1 and 3.0.19 share the same API interface syntax.
This release has been tested with SSDR 2.5.1 and 3.0.27.
- adds hotkeys for RX Filter, MIC, Power levels settings
Note: If you are using SSDR V2.5.1 or later you must use FRStack V3 or later.
Full release history can be found at http://www.mkcmsoftware.com/Flex/Index
A new ReST API interface in FRStack to allow control of FRStack / Radio features. Why? To allow for easy cross-platform control from devices like Stream Deck.
Stream Deck is a tool that sits on your desktop to allow fast access to radio functions. Their website is https://www.elgato.com/en/gaming/stream-deck and it can be purchased from Amazon.
In FRStack Help menu is ReST API information. The FRStack installation folder contains two files for Stream Deck integration. "com.mkcmsoftware.restcall.streamDeckPlugin" is an extension to Stream Deck that adds the ability to make ReST API calls. The second file is a sample Stream Deck profile that you can import that demonstrates control of the Radio via FRStack ReST interface.
The screenshots below show the sample with live radio data.
Mark
W3II
Mark
W3II
7
What version of Stream Deck hardware is this compatible with? There is the XL, normal, and mini.
It will work with any deck model. I am running version 4.3 of the software. If you have a deck already and it functions with their software version 4.3 then you should have no issues.0
Oh No . . . Something else to buy now. A Stream Deck for the flex . . . Ordered and on the way0
Mark
That is so cool. Thanks to Amazon Prime, my Stream Cast deck will be here later today. You have to love same day delivery.
You buy the 15 or the 32 button model
I was thinking the Mini actually, but I went to the 15 button one.0
I got BIG DADDY with 32 buttons so I can do band changing on it.0
What do I need to do integrate FR Stack into the Stream Deck setup software.0
The FRStack installation folder contains two files for Stream Deck integration. "com.mkcmsoftware.restcall.streamDeckPlugin" should be opened one time to install.
"FRStack3 Rest.streamDeckProfile" is also opened to install one time.
The sample is for the 15 button model however it should load in to the larger model.0 -
Is there a list of commands to program a particular button??0
In FRStack Help menu there is a link to get help on the ReST API commands0
Thank you! Thank you! Thank you! I had a standard Stream Deck and recently upgraded to a Stream Deck XL, and I use it more than most of my gadgets. I’ve already set it using macro keys to control FRStack - now I can do this directly! Vy 73, Roy AC2GS0
Great Thanks . . . And I thought I was gonna have a day of R&R here at the Campground0
Does this work while operating remote using Smartlink?0
Yes, FRStack supports SmartLink. You would run FRStack remotely with your Stream Deck integrated to FRStack.
There is a second more complicated way to do this. FRStack ReST API is IP filtered to 127.0.0.1 and ::1 by default. You could specify the remote client IP or allow all IP clients to call the API in the FRStack.exe.config file. Then you would configure your Stream Deck profile to use the new Host, Port address that FRStack is seen at outside of your NAT. You would have to open a port on the NAT to allow traffic through.
I would use the first approach.
Mark, thanks. It is impressive how you continue to expand the utility of FRStacks with useful station workflow and intergration. Congrats and thank you.
This was the initial integration that Jose Lopez EA5SW built using the hotkeys feature of FRStack in June. His efforts inspired me to buy a Stream Deck and create an integration that could display radio data on the deck. "Ideas are made of other ideas."
Very cool ! They also have an iOS version of Stream Deck. Would this work the same as a physical Stream Deck ? I may give this a try with my iPAD Pro.
https://apps.apple.com/app/elgato-stream-deck-mobile/id1440014184?ls=1
This software works like a device. The iPhone / iPad has to connect to the software running on Windows (or a Mac) then creates a new device. I have tested this with my FRStack integration and it works fine on the local network. The iOS device uses a local IP for the connection. Assuming you leave the Stream Deck software and FRStack running on a PC you could VPN in to your home network on the iPhone and use it remotely.
With this software you could take your Maestro and iPhone anywhere in the WiFi network (house) and have enhanced operation.0 -
Thanks for the info Mark. I think I will give it a try and see how it works. This will allow me to try it out before plopping down $$ for Stream Deck hardware. I will probably only use this local in the shack.
Is there a macro template file or way to **** get this up and running quickly ?
Yes, the install folder of FRStack contains the ReST Stream Deck plugin and sample profile.0
Is it similar to the Genovation keypad that runs with DDutil. It does look better. Is it easy to program?
It is easy. FRStack provides the cross platform ReST (web) API and my add-in to Stream Deck makes that easy to call and display values. The biggest bonus with this implementation is the values that get feedback to the keypad.
Mark, Thanks for fast reply. So with 15 keys, how many layers can you have, how many actually keys in total
Mark is there a place where all of us can share screen icon and layouts we have developed so that everyone does not have to reinvent the wheel so to speak?1
I imported FRStack3Rest into Stream Deck. I see some icons on my iPad with Flex things but nothing works. When I look at profile properties there is a warning about no application at path C:/.....SmartSDR Alphav3.14...blah blah.
So how do I make this work for me ? Running SSDR 2.51 Do I have to build a profile for myself ?
Just need a few pointers
Thanks0 -
GitHub ???0
Thanks for your efforts with FRStack - an excellent program for the Flex SDR.
The Stream Deck addition looks very interesting. For SWL it appears one could read a shortwave time schedule database (several on the web), show the station ID's of those currently broadcasting (in one's native language) and display this on the buttons. An hourly update would keep the buttons updated based on the schedule.
_..--
k3Tim
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
