Anyone have CW Skimmer Server working with the new DAX 4.2.18?
I have everything else working great, did all therecommended instal steps and did a factory reset after updating. DAX IQ is set to 1 and it shows as ready, but it never streams the IQ stream. It is as if it is waiting for CW skimmer to tell it to start.
It works fine on the older versions.
Thanks for any ideas.
Tom
N9RU
Best Answers
Thanks Ronny for confirming what I suspected. I only use CW Skimmer on 630 meters and i only use the 8600 for 630 meters now too so I will put it back to a previous version and put it on a mini PC. I don’t think SDC will post to the RBN site.
Thanks again.
Tom
N9RU
You could try SDC Skimmer to replace CW Skimmer.
Tom,
DAX V2 seems to have rendered the CW Skimmer unusable for now. On the one hand, DAX V2 includes some improvements, but some programs no longer work. Because the IQ streams (soundcards) have been renamed, they are not recognized correctly by SDR-Bridge and Slicemaster.
I tried to have a small program created via claude.ai because I’m not a good programmer. But it doesn’t seem to be working very well. The only solution right now is SDC Skimmer.
73 de Ronny DM2RM0 -
I will check it out Mike, Thanks
Tom
I am also unable to get CW Skimmer working with 4.2.18. Worked fine with prior version.0
kevin, this program, still Beta, will get CW Skimmer working again I think, I haven’t tried it yet but will later today.
https://community.flexradio.com/discussion/comment/20627296#Comment_20627296?utm_source=community-search&utm_medium=organic-search&utm_term=smartstreamer
Tom - Thanks. Looks like this replaces SliceMaster. I'll give it a try.0
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 213 DAX
- 387 SmartSDR API
- 67 Aurora
- 310 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
