Anyone have CW Skimmer Server working with the new DAX 4.2.18?
Tom C
Tom C Member ✭✭
edited April 30 in SmartSDR+
I have everything else working great, did all therecommended instal steps and did a factory reset after updating. DAX IQ is set to 1 and it shows as ready, but it never streams the IQ stream. It is as if it is waiting for CW skimmer to tell it to start.
It works fine on the older versions.
Thanks for any ideas.
Tom
N9RU
Best Answers
  • Tom C
    Tom C Member ✭✭
    Answer ✓
    Thanks Ronny for confirming what I suspected. I only use CW Skimmer on 630 meters and i only use the 8600 for 630 meters now too so I will put it back to a previous version and put it on a mini PC. I don’t think SDC will post to the RBN site.
    Thanks again.
    Tom
    N9RU
    Answer ✓
    You could try SDC Skimmer to replace CW Skimmer.
  • Ron DM2RM
    Ron DM2RM Member
    Tom,
    DAX V2 seems to have rendered the CW Skimmer unusable for now. On the one hand, DAX V2 includes some improvements, but some programs no longer work. Because the IQ streams (soundcards) have been renamed, they are not recognized correctly by SDR-Bridge and Slicemaster.
    I tried to have a small program created via claude.ai because I’m not a good programmer. But it doesn’t seem to be working very well. The only solution right now is SDC Skimmer.
    73 de Ronny DM2RM
  • Tom C
    Tom C Member ✭✭
    I will check it out Mike, Thanks
    Tom
  • Kevin KW6E
    Kevin KW6E Member
    I am also unable to get CW Skimmer working with 4.2.18. Worked fine with prior version.
  • Tom C
    Tom C Member ✭✭
    kevin, this program, still Beta, will get CW Skimmer working again I think, I haven’t tried it yet but will later today.
    https://community.flexradio.com/discussion/comment/20627296#Comment_20627296?utm_source=community-search&utm_medium=organic-search&utm_term=smartstreamer
  • Kevin KW6E
    Kevin KW6E Member
    Tom - Thanks. Looks like this replaces SliceMaster. I'll give it a try.
