4.2.18 No RX Stream?
stevenab
stevenab Member ✭✭
I have configured the new CAT port and selected DAX slice 1in SDR. Wsjt-x is working but should the slice1 be green? Let me know what I missed?
    It doesn't look like you have the receiver slice assigned to a DAX port.
    Check this:
  • Neal Pollack AB6G
    Neal Pollack AB6G Member ✭✭
    Also, in the AUDIO settings TAB inside WSJT-X, ensure that you have DAX RX 1 for receive and DAX TX for transmit.
    Neal
  • stevenab
    stevenab Member ✭✭
    thank you! I knew i must have missed something !
  • stevenab
    stevenab Member ✭✭
    Mike, Thank you again for your reply. I had read the instructions and setup the new DAX. The fix was rebooting, again, PC and Radio. When I relaunched everything it just worked? More time needed. Maybe, it the order that I bring thing up? Thanks!
  • DM2DZM
    DM2DZM Member ✭✭
    I've now installed everything on the AU-510M using version 4.2.18. Unfortunately, the DAX application isn't working properly. The RX streams aren't working. If I switch back to 4.1.5, everything works as usual. What can I do about this? Also, the Slicemaster doesn't work with 4.2.18 either. I hope this can be fixed?
  • EdW9US
    EdW9US Member ✭✭
    I done the update this morning and have restarted my computer 3 times wsjt-x is working but DAX does not state that each slice is streaming or show that there is any RX coming from the radio???
  • EdW9US
    EdW9US Member ✭✭
    Figured out my problem it was just a hang up with ssdr or DAX what I did
    with ssdr running 4 slices and wsjt-x closed down I closed out all the slices then brought them back up 1 by 1 and when I did this DAX showed each slice ready then I started wsjt-x up slice A thru D and DAX went to streaming showing RX gain to each slice so it was ssdr or DAx with a hang up not sure but this got everything going like it should.
