Profile Auto Save Discussion
Dennis, to each his own....I hate the AutoSave "feature"... We definitely should have the option to use it or not. 73.
What would be nice is if they could have profile “memories” like the frequency memories. This way if you move a slider in the current working profile it stays “moved” even on band changes. But you could then load a profile “memory” which is a saved snapshot of a profile.
You can do that by exporting profiles once set up and then importing them but would be better to have it self contained.
That way the current profiles will have a knob or slider change stay persistent but you could then load the profile “memory” which would overwrite the settings in the current working profiles
Best of both worlds and should be satisfactory to all.
Just my thoughts.
-1 -
I really really don't like it! Switch Please!
Johan, SE3X
My Profiles should never change unless I change them. Autosave takes away all the advantages of the profile concept and reverts the radio to a knob type older radio. This looses one of the big advantage of of owning an SDR radio.
Those who want it to work like a knob radio should buy a knob radio.
How many non SDR radios have user defined profiles to set the knobs.
If there are any, do their profiles change automatically?
I am willing to learn but I don't want autosave on my SDR.
Don2 -
There is persistence memory and there is profile memory. Profile memory can only be changed manually. If you change something it is saved in persistence memory. And when you shut down SmartSDR and the radio the last save memory will be what you see when you turn on the radio and SmartSDR. To get back to your preferred settings simply recall the profile. If you want a change to stick. Save the changes under the same profile name, AND make sure you export to computer memory to have a permanent record for recall in a radio/software failure. Or if one has to do a factory reset.
Hi Tim,
I emailed Eric and Gerald back in September and October to see if this means the AutoSave On/Off switch is really coming. At least that is what I took Mike's reply to infer. So far no replies.
Seems there has not been much focus on SSDR enhancements lately but some feedback and communication like in the old days would be appreciated.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 Win10 SSDR V2.4.10
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
