FRStack Version 3.1.3.7 Released - Stream Deck support
The entry is in MHz so you enter 7.255 not 72550000
So, does it mean I can't enter 14020825 ?0
you would enter it as 14.0208250
Mark. I am playing around with Touch Portal which is very similar to Stream Deck. They will have a SDK available soon. In the mean time would it be posible for me to issue calls to your REST api via a script using curl ? Not looking to display any radio data back into Touch Portal buttons. Just want to select profiles which are not available via hotkeys in FRStack. Thanks -Joe
Could someone point me to the numeric keypad deployed on the Stream Deck...I can't seem to find it in the menu...thanks in advance
Regards,
Ronald0 -
Mark here is a suggestion. Can you make your home deck empty with a button to your FRstack Profile or at the very least place a button where we can make our own, like get a profile, or a folder of our choice. Here is the reason. Each time you update FRstack we have to reinstall the profiles because of the new features and fixes you do. This makes profiles I make up kinda useless. With the home profile available for new button, I could simply copy my buttons over. Does that make any sense to you?
When I add the same profile back to my Stream Deck it creates a new profile entry. Then I can copy the buttons or folders from this new profile to the existing profiles I use. I do not understand how this is different from what you are asking me to do.0
If you are using the latest sample profile from FRStack3 then open the Frequency folder it is under the keypad looking folder.0
Yes the Rest API Help in FRStack references how to use CURL0
Thanks Mark...I was not using the current profile... Ronald0
Mark,
I bought a stream deck(15 button). Downloaded software. from stream deck.
Went to properties and clicked on the two files. Don't see them In my stream setup.(software)
At 81 years old, I'm having trouble setting stream up. Can see sdr and frstack3 in profile set, but don't see anything like that on right side of keyboard.
But can't find it after I click on it.
Can anyone walk me through the setup.
TU...Don...w2xb
Don. See the post by Mike Walker in this thread. He posted instructions on how to get everything working.
I didn't explain well Mark sorry. I guess first my question, the 2 files to be executed are just your profiles or is there updated code to perform more features ? In other words is there any need to execute them for each FRstack update?
As per the home folder, I guess going forward I can just use yours as a basis to copy buttons to my customer 6700 profile.
Don, I volunteer to log to your computer and help you with the set-up, if you need.0
The plugin performs the REST calls from Stream Deck and I will call that out in the what has changed for the release. There are many releases lately due to adding requested feature this should slow down shortly. The profile is usually updated with the newly exposed features. So only if you want to use the new feature do you need to update.0
It works, I can enter the frequency as described by Mark. Thanks!
need a Little help, making progress but when I click on the two files in frstack for plugins or profile,they won't open.
Don...w2xb
They’re not supposed to open. They just load and that s it. The profile will load when u open the stream deck software0
Steve, I was about to ask for this feature. Great minds think alike. Ha-Ha0
Mark, I hope you realize you've open a can of worms with this gadget. Great software. Again thanks0
Mark, I'm helping Don in setting up StreamDeck.
For some reasons the RESTtAPI server doesn't run (I just checked with a browser) and the restAPI applet doesn't load in the StreamDesk software, so no communication. I checked the firewall, the network configuration, everything looks good. I also run as administrator. I suspect something is going wrong with the Antivirus. Any suggestion?0 -
You must double click on the files. THe first will open and go through an install sequence. The second doesn't open but installs silently.
Michael -- KM6LHD0 -
Make sure the files are not "BLOCKED" by Windows. In Windows Explorer right click the select Properties. On the bottom of the General tab, is there a Security warning about the file coming from another computer? If so select Unblock and then click OK.
The restApi server is not running, read my post0 -
Do you mean the 2 StreamDesk files? The FRStack restapi server should respond anyway, right?0
Get my email address from QRZ or Contact Support link in FRStack. send me your phone number and I will call.0
Mark thanks for the great program and the ability to work with Stream Deck. I have one cosmetic issue I cannot resolve...in the main menu select Slice...on the right side second button I see Slice with a line thru it and I can't find a way to remove it ...can you or someone give me some guidance on how to clean this up...thanks
Regards,
Ronald0 -
This is the image file set for the button. You can change this by selecting the button then using the context menu on the button's upper right corner. You can find the images I used to create the profile at https://github.com/mkcmsoftware/FRStack_Stream_Deck/tree/master/SD_ICONS
Problem solved, the custom plugin was not recognized by StreamDeck but by Internet Explorer even if I tried to force it.
Always verify the selection 'OPEN WITH: Stream Deck'
Thanks0
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 724 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 943 Third-Party Software
