Ugly 20KHz wide signal on 15M
Barry N1EU
Anybody else seeing this 21.320-21.340MHz?
Yep0
Not in Colorado.
yes I hear it also
Jim
Woodlawn TN
Me too in Barbados
Yes, peaking around 120-130 degrees from me. Almost certainly from Iran or Cyprus. I see a lot of these around the bands. Probably not new, just that SDR sees what conventional radios never did.
73 de Steve G1XOW0 -
Thanks Steve. Although I'm often on 15M on Saturdays at this time, I've never seen this before. Oh well.0
It is coming from NE for me in Barbados. Definitely somewhere Europe.
If I point 45 North East I can get an S8.0 -
Same here Sal, solid s9 on my 3-el.0
Not nearly as ugly here in Central Oklahoma...0
Seen and heard in NC too.0
I checked with my remote station in Madrid and it looks indeed like Middle East.
From Barbados is 50 degrees North East.
From Madrid, Spain it is 95 to 100 degrees due East (slightly South East)0 -
have the same signal in denmark
oz1op
screenshot from denmark
OZ1OP
As propagation improves its getting pretty crazy.
Signal of 9 now.
Not detect in in this region, however they mostly appear here on 12 & 17 meters many times much stronger & with wider bandwidth during the day. I will do post next time it appears over on this side.0
it's here as well (West Central Florida) but not nearly as strong.0
Ali,
Is it East or West of you?
Do you see it at all?
i have seen it on a lot of frequency, if you zoom out enough you will notice the systeme transmitt a kind of "ping" on a LOT of band and automaticly choose the frequency that respond best for the time of the day. a friend of mine (military) say it's the russian CONTAINER RADAR that is about 1 year ahead of its posted realesead time. it seem that they use this to track any flying object (plane, missile)...0
I have acknowledged their transmission and they are beaming me up now.
Seen that one but saw another few weeks ago that had "FREE UKRAINE" written inside it, very clever0
Don't step into that one Ross.. It is a Beam Scattering technique.... Ross... hello.... Ross...1
I have my beam pointing west of north most of the time at 320 Deg.
If I detect them again I will find out at which direction I would get a peak, surely it comes from the northern direction.0 -
Sorry guys, that's me. I need to adjust my transmitter...0
Here it is again. Now in the middle of the CW section of the 17 meter band
73 de OZ1OP / Ole.
That Syrian radar or whatever it is just popped up on 17m right in the middle of my QSO with RA1QEA, taking up the band from 18.060 to 18.080. Fortunately with my 50hz CW filter engaged I was able to finish the QSO!0
on 30m 10.120 to 10.140 right now0
In Moscow mentioned above not visible at afternoon today however others looks like:
- 197 SmartSDR+
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
