Ugly 20KHz wide signal on 15M
Barry N1EU
Barry N1EU Member ✭✭
Anybody else seeing this 21.320-21.340MHz?
  • Lewis Cheek
    Lewis Cheek Member ✭✭
    edited January 2018
    Yep
  • K0UNX
    K0UNX Member ✭✭
    edited June 2016
    Not in Colorado.  image
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    edited June 2020
    yes I hear it also
    Jim
    Woodlawn TN
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Me too in Barbados
  • G8ZPX
    G8ZPX Member
    edited July 2018
    Yes, peaking around 120-130 degrees from me. Almost certainly from Iran or Cyprus. I see a lot of these around the bands. Probably not new, just that SDR sees what conventional radios never did.
    73 de Steve G1XOW
  • Barry N1EU
    edited February 2017
    Thanks Steve.  Although I'm often on 15M on Saturdays at this time, I've never seen this before.  Oh well.
  • EA4GLI
    EA4GLI Member ✭✭✭
    It is coming from NE for me in Barbados. Definitely somewhere Europe.
    If I point 45 North East I can get an S8.
  • Barry N1EU
    Same here Sal, solid s9 on my 3-el.
  • Gary - WB5ULK
    Gary - WB5ULK Member ✭✭
    edited March 2018
    Not nearly as ugly here in Central Oklahoma...image
  • Tim - W4TME
    edited March 2017
    Seen and heard in NC too.
  • EA4GLI
    EA4GLI Member ✭✭✭
    I checked with my remote station in Madrid and it looks indeed like Middle East.
    From Barbados is 50 degrees North East.
    From Madrid, Spain it is 95 to 100 degrees due East (slightly South East)
  • ole puschl
    ole puschl Member
    edited February 2016
    have the same signal in denmark
    oz1op
  • ole puschl
    ole puschl Member
    screenshot from denmark
    OZ1OPimage
  • EA4GLI
    EA4GLI Member ✭✭✭
    As propagation improves its getting pretty crazy.
    Signal of 9 now.
  • Ali  9K2WA
    Ali 9K2WA Member ✭✭
    edited March 2017
    Not detect in in this region, however they mostly appear here on 12 & 17 meters many times much stronger & with wider bandwidth during the day.  I will do post next time it appears over on this side.
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited May 2019
    it's here as well (West Central Florida) but not nearly as strong.
  • EA4GLI
    EA4GLI Member ✭✭✭
    Ali,
    Is it East or West of you?
    Do you see it at all?
  • VE2MBT
    VE2MBT Member
    edited November 2019
    i have seen it on a lot of frequency, if you zoom out enough you will notice the systeme transmitt a kind of "ping" on a LOT of band and automaticly choose the frequency that respond best for the time of the day. a friend of mine (military) say it's the russian CONTAINER RADAR that is about 1 year ahead of its posted realesead time. it seem that they use this to track any flying object (plane, missile)...
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    edited December 2017
    I have acknowledged their transmission and they are beaming me up now.
  • Gary m0gme
    Gary m0gme Member ✭✭
    edited December 2016
    Seen that one but saw another few weeks ago that had "FREE UKRAINE" written inside it, very clever
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Don't step into that one Ross..  It is a Beam Scattering technique....  Ross...  hello....  Ross...
  • Ali  9K2WA
    Ali 9K2WA Member ✭✭
    I have my beam pointing west of north most of the time at 320 Deg.
    If I detect them again I will find out at which direction I would get a peak, surely it comes from the northern direction.
  • Rob N4GA
    Rob N4GA Member ✭✭
    edited January 2017
    Sorry guys, that's me. I need to adjust my transmitter...
  • ole puschl
    ole puschl Member
    Here it is again. Now in the middle of the CW section of the 17 meter band
    73 de OZ1OP / Ole.
  • Rick Hadley - W0FG
    Rick Hadley - W0FG Member ✭✭
    edited January 2018
    That Syrian radar or whatever it is just popped up on 17m right in the middle of my QSO with RA1QEA, taking up the band from 18.060 to 18.080.  Fortunately with my 50hz CW filter engaged I was able to finish the QSO!
  • DaveC
    DaveC Member ✭✭
    edited May 2018
    on 30m 10.120 to 10.140 right now
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    In Moscow mentioned above not visible at afternoon today however others looks like:
