SmartSDR v1.6 video
6 hours late and a dollar short.0
Ernest you must have the patience of a saint!
Maybe throw a chunk of wire across the bedroom?0 -
When I was in grad school, i made a full wave loop for 20 meters (roughly 16 ft per side) and hung it from the suspended ceiling tracks around my room with paper clips, fishing line, and rubber bands. I made contacts around the country, but I also contacted several of cheap stereo systems and TV's in other apartments in the dorm! Don't let antenna restrictions keep you off the air! A BAD antenna is better than NO antenna! (But it is frustrating if you once had a GOOD antenna.)
Ken - NM9P2 -
Oops...Flex down-res'ed it to 360P. Too fuzzy to see the details.
Chris's original was HD.0 -
Takes a little while for youtube to process videos.0
I missed Chris's video but this is just fine by me.
Great Job everyone at FRS!
KC2QMA
John0 -
Big Tease, Enough Already! Lol..0
When I try to view the video, youtube says it is private.0
If FRS keeps the re-published one Public, I will flip mine public too. I do not want to do it first without asking.0
Bob, are you familiar with Abyssmedia's Multi-channel Recording System program?
I use it to record 8 time stamped audio streams operating VOX simultaneously (it is capable of more than 8 separate channels for an additional price).0 -
I've gotten the all clear, so it is now set public again.
Thank you all for the positive feedback, but the real praise should go to Flex for making this upcoming release so fantastic.
Hi Roy,
I had noticed that program back when I bought i-Sound, but have not thought of it since.
If 1.6 is not out in the next few days or doesn't have a way of combining transmit and receive audio, I will give their demo a try. Thanks for the information.
73, Bob, N7ZO
You're welcome!
Another option is to use something like Virtual Audio Cable to merge two audio streams (DAX REC 1 and DAX MIC) into a single audio channel and record that stream using i-Sound Recorder?
Since I already have MCRS, I will just dedicate two of its 8 channels to DAX REC 1 and DAX MIC and name the files so that they will interleave in the file directory - then I can use MP3 Splitter Joiner Pro to merge a QSO into a single MP3 file.
Who would have thought this kind of stuff would be available a few years ago?
Ain't technology grand!0 -
Mind = blown0
And when it comes out, do yourself a favor and take a look at the documentation. You'll have a more harmonius outcome.
WOW, will not be able to sleep tonght he he ... mouth watering.....now I need to win the lottery for a 6700 and would need a 50 inch monitor. I think by looks you need a good job0
Very impressive and I can see I've a learning curve ahead of me. Very much appreciate the advance look and what is obviously a huge effort to bring very powerful new capabilities to the end user supported by cool videos like this! Thank you for the look! 73 Steve K9ZW1
Now I hope we get split sorted for RTTY awesome stuff thanks Flex this is exciting0
I am so ****, after watching this video I want to sell my 6300 and buy anything but a Flex. I have a life outside of ham radio and if I have to go through all this to go on the air, forget it. The video is extremely well done and narrated, this reminds me of the early 90s when you had a long setup using something called Trumpet to get on the internet.
Trumpet Winsock was easy to configure, unlike Phil Karn's KA9Q which was the only way to get on the Internet with a PC in the very early 90's. I disagree with the main sentiment of your comment though Burt. In my mind, it shows how complex a setup it is possible to create but you absolutely don't need to go to these lengths just to use the radio!0
Brilliant Barry, I hope FlexRadio are paying you for that, they certainly should be.
Its a great promotional video for the product.
best wishes
G4BIM Isle of Wight U.K.0 -
My point is before DAX it was a harder setup, couldn't some of the setup in the video be automated as the internet later became and as DAX allowed? If you showed this video to new potential buyers, there would be few potential buyers. But the video is extremely well done.
It is a great video, promotional it is not.
I would just like to inject a different point of view. As mostly an outsider I have heard and read comments after previous releases about the incomplete Beta testing of the software.
I think this video shows, at least from a data mode perspective, that the person whom made the video takes the role of beta tester very seriously.
To this person...simply thank you.
John K3MA2 -
So your opinion is that oms will not buy things that have lots of menus and buttons and cables to connect to do digital modes and are complex to setup... Interesting. This is for you Burt https://youtu.be/PF7EpEnglgk1
Actually, except for showing how complex a setup one can make, it demonstrates to me a level of increased simplicity...only one TX DAX channel; only one column in the DAX control panel which is combined with the CAT panel; right-click on individual DAX or CAT Channel designators in order to adjust properties; CAT properties selectable by clicking on buttons; simpler setup of CAT channel, DAX channel and PTT for digital modes; easy automated selection TX active channel for multiple digital modes; different slices mapped to VFO A status for logging purposes.....and more. I like what it see. But this video was created to show other alpha testers how the new software can push the cutting edge, it isn't a simple tutorial to teach noobies how to set up a simple digi operation. I imagine that will be forthcoming...or I will make one myself once I get a chance to master 1.6 when it is released. Ken - NM9P3
Is that because it tells the truth ???
This discussion has been closed.
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 223 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
