Hercules MIDI with 6300
Ken, I've no idea if they are rotary encoders or with detents. I just saw the device, watched the video and brainstormed some potential use cases.0
What about this? Each dial has an alternate function when "press turned". Also a shift button for alternate switch functions. This is of course on the assumption the dials are encoders.
The LED's in the encoders/ slider will show same value as SmartSDR. But this means I have to parse a ton more data.
Also think I will make the step button switch between 1/10/50 then add a step x10 button for fast movement. So when on 10hz step the x10 button will switch it to 100, and 50 to 500, etc etc.
This will be my most extensive project to date, but I think it will be AWSOME when its done.
Thoughts?
Have two TX selects oops, but yall get the idea
Looks and sound good. I like the shift button.0
I just looked they are all endless rotary encoders
Wonderful! That just increased their value! 8 rotary encoders!
You can encode them in the same way that you do the mode shift button, but with a high end and low end stop. Other commands you can do like the rotary encoders for RIT/XIT.
I am going to enjoy this one when it arrives! It may even become my main MIDI control.0 -
By "press tuned" do you mean like a function toggle button, or press-and-hold-down while tuning? I like the first, but do not like the last. I always seem to let go too soon with a press-and-hold tuning button.0
I was thinking that the pushbutton function of the 8 knobs would work as an individual shift button for that particular knob. The shift button is still a good idea, but if each knob can be shifted individually by just pressing the knob you already have a hold of, that would be much better than releasing the knob, hitting shift, finding the knob again. I'm just thinking workflow during contesting, and not having to hunt the shift button for the knobs would certainly speed things up. To be clear, i'm envisioning pressing the knob as a momentary action, not one to be held while making the adjustment.
Also for the RIT/XIT on/off and shifted clear function, maybe holding the button for 1 second would clear rather than hitting shift? Contest types may want a 500msec instead, but then I suppose you could expose that variable as a user configured value.
From an old sound engineer standpoint, it makes sense to me to put the master volume on the big fader, and move VFO volume to go live with HP volume. Probably just personal preference though.
Not sure what "bandwidth" refers to under "mic level" is that the panadapter zoom? If so, that's a GREAT idea.
I'm with you William, this is going to be AWESOME.1 -
Ken its a toggle not a press an hold, at least that is how I'm coding it. I guess you can code it any way you like.
Sounds good. Boolean logic for a status toggle, IF/ELSE for variable function. Should be easy going!0
All,
For the CMD PL1 I will need much more data from the radio. Currently the CMD micro only queries Freq, slice, mode. So I started a new parse routine to use with the PL1. Currently the parsing is working good for Freq,slice,mode,pan,agc,slice vol,balance,tx low,tx high, rx low, rx high, bandwidth for slice A and B. I still need to add in Main volume and a few others.
So that was the biggest hurdle. If anyone cares to look at how I did this;
https://www.dropbox.com/s/cw9fu6s993hxxd8/Flex_Parse.pde?dl=0
William
Updated Version History
https://www.dropbox.com/s/lq8stg32ooqhy4y/CMDMicroFlex6K%20Version%20Release%20Notes_9e.docx?dl=0
Thanks I was looking for a bit of code I changed a few revisions back, but couldn't find it. your doc helped me locate it. I'm very unorganized, more OCD
william
I'm looking to limit the available modes on the CMD for speed. Which modes do you really need on a controller. I think digi modes should just be done on the pc where they belong.
My thoughts are USB,LSB,AM,CW and that's it. Opinions?0 -
DIGU, NFM modes needed here...0
ok
Maybe a list of available modes can be made in a user editable file. This way people can choose the modes they use.
For me I am 99% phone, but others may be 99% Digi or CW.
William
I'm thinking that are any modes needed at all on the CMD? My use case is putting frequently accessed settings within easy reach. I don't change modes very often in a session, so taking up a spot on the CMD is of limited value to me. However, I think the USB, LSB, AM and CW would cover it, but I would substitute SAM for AM.0
William,
I think editable list would be a better option. In my case, I would set it to DIGL, USB, SSB, CW.
Javier1 -
Javier, I concur with an editable, or dropdown list.0
william I installed only version 1.9E, the program runs, but does not find the flex6500. With older version of your program, not numbered, by entering the IP Flex 6500 CMDMicro runs good. A suggestion? win 8.1 Tnx Fabrizio IK6DLK0
It seems I'm having a similar problem with my 6500. I've downloaded V1.9e and get no ip connection to the radio. The CMD window appears on my desktop and there's some interaction between the desktop and the controller but not with the radio. This is the 1st attempt to get this working with my 6500. I did have an LE with my old F5K but that was a different setup. Also it appears after I installed the software and the controller found its driver my desktop icons got scrambled and enlarged during a reboot. ??? I'm running i7, win7 64bit, 16gb ram and dual video cards.0
V1.9e is working OK here. Also running i7, win 7 64 bit, but only 1 video card.
Bernie, W4BGH
Fabrizio,
You are the first to report this issue with discovery. I'm not sure what it could be without being there. However I made you a custom version of the newest version that uses manual IP. This should allow you to use the latest features. Please try the original software on different workstations and check the obvious things such firewall settings etc.
https://www.dropbox.com/s/gap6unikww23mk1/CMDMicroFlex6k_v1_9e-manual.zip?dl=0
Joe,
The software does not modify anything in windows. It actually does not install at all. Its just a standalone portable app. Any changes to your windows Icons must purely be coincidental.
William
The discovery issue could be slow network response. The APP listens for 3 seconds before deciding giving up. With my nework and radio I receive 4 UDP messages within that time. Maybe this is just not long enough for slower networks. I will post a new version tomorrow with a longer timeout. Until then please use the manual version I just posted. I am away from my main workstation with all my data.
William
Thanks William, I'll try it tonight when I get home.0
I loaded the "Manual" version last night and took a small step forward.
After entering the IP i can now see the frequency readout on the CMD screen for VFO A and if I add a B VFO/Slice that appears also. If I change freq using my Flex Kno or Mouse the Freq on the CMD screen follows along.
However, I get no response from the CMD device controls. NaDa!
I did uninstall the previous version of 1.9e automated IP version bdefore installing the Manual version.
Joe
Joe,
The program can not contact the CMD Micro. Please use this midi test software to see if the CMD Micro is even working.
If this software does not show CMD Micro as an option in the dropdown, the Micro is not working. This is most likely a driver problem on your PC.
Also check device manager and see if the CMD Micro is there.
http://forum.djuced.com/files/p_download/137/miditest.exe
William
All,
I have the CMD PL-1 partially working. Wow this guy has my head spinning. Its taken me a good amount of time to figure this guy out. The Deck button switches channels, and this is actually sorta a pain.
So far I have the VFO working with steps 1/10/50hz and the x10 button . Also I have waterfall bandwidth, main vol, headphone vol, vfo vol working.
This controller is surely more of a challenge, but I will get all the functions working with time. I just wish I could control the deck selection via software, so it would just cycle 1-2 only.
I have a video uploading that shows the above functions working that I will post in a bit.
William
William, You could make your control IF/THEN statements active in multiple decks with something like: IF ((channel == 1) || (channel == 2)) && (pitch == 20)) Then do this function.... That would allow you to use the same buttons on most of the controller when you change the VFO channel. You could also have the different decks allow a different layout for some functions. But that could get really complicated... Ken - NM9P0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
