Remote Antenna Tuner
Tom C
Tom C Member ✭✭
I can’t find anyone that sells a high power remote tuner I could use with the Aurora. I really would like to have the tuner at the antenna
Has anyone heard if the Acom 04AT could be made to work with the Aurora? Even finding an used remote tuner is tough.
Tom
N9RU
  • JasonSt
    JasonSt Member ✭✭
    Elecraft KAT500
    403a Tuner Genius XL
    73 de KD9ZHF Jason
  • Tom C
    Tom C Member ✭✭
    I have a TGXL but want something I can put at the base of the antenna.
    You could do what I am doing. I'm putting the AU-520 at the base of the tower. It is about the size of high power tuner and now I have the entire solution there and I only have to run a 'typical' 120VAC circuit.
  • Tom C
    Tom C Member ✭✭
    edited July 27
    Interesting, what is it housed in? I could possibably do something like that with the TGXL.
    edited July 27
    This is a Hammond cabinet that is 24"x24"x18" deep.
    It will have the AU-520 on the top with:
    BTW, with that depth, the radio will either fit 'normally' (I'll have it in backwards so the back is at the front) or even sideways. If you can see the line on the plywood, that is the width of the radio from the left.
    And, on the bottom
    • 2x8 Antenna Genius - I have yet to cut the 3" entry hole for all the cables.
    • Sensors for the LP-100 but I might use the Wattmeter in the Station Controller
    • Lightning Protection System controller
    • AC Power + power bar with surge protector
    • LAN Switch
    Since I am in Ontario, the isolation is required to not let the Sun heat it up too much and hence the AC fan which actually moves LOT of air. I know from history, it will only get a few degrees hotter than the outside air if I keep the sun off it.
    In the winter, there will be a 25 watt heating pad underneath the radio. I've been doing this for 20 years, so I know that is enough heat to keep the radio running just fine all winter.
    And, I am getting rid of 135' of feedline that goes to the shack so a LOT less RF loss for both TX and RX. In todays world, there is now no need to have the radio actually where the operator is.
    (sorry, I got carried away)
  • Tom C
    Tom C Member ✭✭
    Very nice Mike. I think I will do something similar for just the TGXL.
    Thanks for the ideas!
    To
    N9RU
  • Rich - N5ZC
    Rich - N5ZC Member ✭✭✭
    4O3A.com announced an out door TGXL, https://4o3a.com/tuner-genius-outdoor
    I email 4O3A frequently. The last email I received from Ranko was in June and I was told pre-orders would start on July 1st, which has not happened.
    So at this point its just vaporware, quite frustrating.
    Rich - N5ZC
  • Tom C
    Tom C Member ✭✭
    I saw this when looking yesterday.
  • Rich - N5ZC
    edited July 28
    Tom,
    Its been on WIMO's website for some time.
    An Elecraft KAT500, Raspberry Pi and PgTgBridge software is another option I'm looking at. It would be fairly easy to mount a KAT500 in an outdoor NEMA box. While Elecraft won't guarantee the specs, they feel comfortable that it could handle the temperature swings it would be subject to in an outdoor environment.
    Rich - N5ZC
  • Tom C
    Tom C Member ✭✭
    That’s another good idea Rich. I appreciate all the ideas. I think if Mike is brave enough to piut the Aurora outside, I will do something similar with my TGXL.
    It works so well remotely it should work out well.
    Tom
    N9RU
  • Rich - N5ZC
    Tom,
    I've thought about using a TGXL as well. I wonder if the current TGXL is rated for the temperatures it may see in an out door environment. I'm not worried about the cold temperatures, but I am worried about heat.
    It would be interesting to know if 4O3A is just repackaging a TGXL or if they are making component changes as well.
    Its been in the low 100's here since last week, then put it in a steel or fiberglass box….
    I think a fan like @VA3MW is doing would be mandatory.
    I don't have the lucky charms to place an AU-520 out in a box, plus the AU-520's internal tuner is an SWR flattener (sp?) it won't handle large impedance excursions. I'd rather place a less expensive unit out at the tower.
    Rich - N5ZC
  • Tom C
    Tom C Member ✭✭
    it looks like the specs anyway say it would be ok for my area. A pretty wide range.
    13 Specifications
     Tuning: Fully automatic and manual tuning
     Frequency Range: 1.8 to 30 MHz continuous plus coverage of 6 meters
     Radio Interface: LAN, CAT RS-232, CI-V, BCD, Pin-to-Band (PTB), frequency sense.
     Alarms and Warnings: Low drive, Freq Out of Range, Wrong Band, High power, >10:1 SWR
     Matching Range: Up to 10:1 SWR.
     Tuning Time: Tuning solutions (2 to 12 seconds)
     Stored memory switching: < 20ms.
     Tuning Power Requirement: 10W - 200W
     RF Power 2000W maximum
     Exciter Inputs 2 – SO-239
     Antenna Outputs 2 – SO-239
     Antenna Impedance 50 ohms unbalanced
     Cooling Thermostatically Controlled Fans
    Mechanical Specifications
     Dimensions  Weight 11.8” W x 13.8” D x 5.9” H (30cm W x 35cm D x 15cm H)
    15.4 pounds, 7 kg
     Operating Temperature -4°F (-20°C) to +122°F (+50°C)
    Electrical Specifications
     Supply Voltage and Current 12 - 16V DC @2A
    14 FCC Statement
    This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
     This device may not cause harmful interference, and
     this device must accept any interference received, including interference that may cause undesired
    operation
    FCC ID: 2AK7NSKYTuner Genius XL001
    Page 67 of 74
    Copyright 2023 FlexRadio. All Rights Reserved. 10 January 2023(FW:1.1.16, Utility: 1.1.16)
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    You could always use a suitable Peltier cooler.
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    If I could have a tower, I'd definitely build or buy a nema protected enclosure and put the radio there. I'd run 110V or 220V if needed and a shielded ethernet cable through conduits.
    The dream for me would be a tower, maybe with SteppIR beam and radio right below. But never gonna happen. But that is how I would do it if I could.
  • Mark_WS7M
    For heat concerns on outdoor equipment I'd probably do sealed water cooling through a radiator. You'd have to empty / flush it for winter but it would certainly keep things cool during the heat.
    We've done this for a few high-resolution instruments we've installed where the A/D card needs to be kept cool. We originally were gonna just use CPU coolers but then found we would do an overall radiator system that would keep everything cool and a big heatsink on the A/D chip.
  • Tom C
    Tom C Member ✭✭
    The thing I love about this group is all the good ideas and info available.
    Thanks for all the suggestions, I will post a picture when I get it all figured out.
    Tom
    N9RU
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Mikes idea of installing the Aurora with the connection side (back) available is really good since the front doesn't do anything useful anyway. Most rack equipment is mounted with the wiring in the back, which can sometimes make access difficult.
    @Mark_WS7M Cool idea (pun intended) :)
    For the past 6 or 7 years I have been running the PGXL in a very tightly spaced cabinet and even with a similar fan for air only cooling, I had no problem managing the temperature. Just to be sure, I had a Temp probe on each shelf. It turned out to be pretty simple and reliable.
