Remote Antenna Tuner
Elecraft KAT500
403a Tuner Genius XL
73 de KD9ZHF Jason0 -
I have a TGXL but want something I can put at the base of the antenna.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou could do what I am doing. I'm putting the AU-520 at the base of the tower. It is about the size of high power tuner and now I have the entire solution there and I only have to run a 'typical' 120VAC circuit.
Interesting, what is it housed in? I could possibably do something like that with the TGXL.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis is a Hammond cabinet that is 24"x24"x18" deep.
It will have the AU-520 on the top with:
- Rotator Genius,
- Steppir Controller,
- LP-100 watt meter,
- Sierra Radio Systems Station Controller on a DIN mount on the back right (that is why the wood
BTW, with that depth, the radio will either fit 'normally' (I'll have it in backwards so the back is at the front) or even sideways. If you can see the line on the plywood, that is the width of the radio from the left.
And, on the bottom
- 2x8 Antenna Genius - I have yet to cut the 3" entry hole for all the cables.
- Sensors for the LP-100 but I might use the Wattmeter in the Station Controller
- Lightning Protection System controller
- AC Power + power bar with surge protector
- LAN Switch
Since I am in Ontario, the isolation is required to not let the Sun heat it up too much and hence the AC fan which actually moves LOT of air. I know from history, it will only get a few degrees hotter than the outside air if I keep the sun off it.
In the winter, there will be a 25 watt heating pad underneath the radio. I've been doing this for 20 years, so I know that is enough heat to keep the radio running just fine all winter.
And, I am getting rid of 135' of feedline that goes to the shack so a LOT less RF loss for both TX and RX. In todays world, there is now no need to have the radio actually where the operator is.
(sorry, I got carried away)
Very nice Mike. I think I will do something similar for just the TGXL.
Thanks for the ideas!
To
N9RU
4O3A.com announced an out door TGXL,
I email 4O3A frequently. The last email I received from Ranko was in June and I was told pre-orders would start on July 1st, which has not happened.
So at this point its just vaporware, quite frustrating.
Rich - N5ZC
Tom,
Its been on WIMO's website for some time.
An Elecraft KAT500, Raspberry Pi and PgTgBridge software is another option I'm looking at. It would be fairly easy to mount a KAT500 in an outdoor NEMA box. While Elecraft won't guarantee the specs, they feel comfortable that it could handle the temperature swings it would be subject to in an outdoor environment.
Rich - N5ZC
That’s another good idea Rich. I appreciate all the ideas. I think if Mike is brave enough to piut the Aurora outside, I will do something similar with my TGXL.
It works so well remotely it should work out well.
Tom
N9RU
Tom,
I've thought about using a TGXL as well. I wonder if the current TGXL is rated for the temperatures it may see in an out door environment. I'm not worried about the cold temperatures, but I am worried about heat.
It would be interesting to know if 4O3A is just repackaging a TGXL or if they are making component changes as well.
Its been in the low 100's here since last week, then put it in a steel or fiberglass box….
I think a fan like @VA3MW is doing would be mandatory.
I don't have the lucky charms to place an AU-520 out in a box, plus the AU-520's internal tuner is an SWR flattener (sp?) it won't handle large impedance excursions. I'd rather place a less expensive unit out at the tower.
Rich - N5ZC
it looks like the specs anyway say it would be ok for my area. A pretty wide range.
13 Specifications
Tuning: Fully automatic and manual tuning
Frequency Range: 1.8 to 30 MHz continuous plus coverage of 6 meters
Radio Interface: LAN, CAT RS-232, CI-V, BCD, Pin-to-Band (PTB), frequency sense.
Alarms and Warnings: Low drive, Freq Out of Range, Wrong Band, High power, >10:1 SWR
Matching Range: Up to 10:1 SWR.
Tuning Time: Tuning solutions (2 to 12 seconds)
Stored memory switching: < 20ms.
Tuning Power Requirement: 10W - 200W
RF Power 2000W maximum
Exciter Inputs 2 – SO-239
Antenna Outputs 2 – SO-239
Antenna Impedance 50 ohms unbalanced
Cooling Thermostatically Controlled Fans
Mechanical Specifications
Dimensions Weight 11.8” W x 13.8” D x 5.9” H (30cm W x 35cm D x 15cm H)
15.4 pounds, 7 kg
Operating Temperature -4°F (-20°C) to +122°F (+50°C)
Electrical Specifications
Supply Voltage and Current 12 - 16V DC @2A
14 FCC Statement
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
This device may not cause harmful interference, and
this device must accept any interference received, including interference that may cause undesired
operation
FCC ID: 2AK7NSKYTuner Genius XL001
Page 67 of 74
Copyright 2023 FlexRadio. All Rights Reserved. 10 January 2023(FW:1.1.16, Utility: 1.1.16)
You could always use a suitable Peltier cooler.
If I could have a tower, I'd definitely build or buy a nema protected enclosure and put the radio there. I'd run 110V or 220V if needed and a shielded ethernet cable through conduits.
The dream for me would be a tower, maybe with SteppIR beam and radio right below. But never gonna happen. But that is how I would do it if I could.
For heat concerns on outdoor equipment I'd probably do sealed water cooling through a radiator. You'd have to empty / flush it for winter but it would certainly keep things cool during the heat.
We've done this for a few high-resolution instruments we've installed where the A/D card needs to be kept cool. We originally were gonna just use CPU coolers but then found we would do an overall radiator system that would keep everything cool and a big heatsink on the A/D chip.
The thing I love about this group is all the good ideas and info available.
Thanks for all the suggestions, I will post a picture when I get it all figured out.
Tom
N9RU
- 691 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 113 Aurora
- 349 FLEX-8000 Signature Series
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 323 Shack Infrastructure
- 228 Networking
- 484 Remote Operation (SmartLink)
- 146 Contesting
