RF gain?
Bill M
Bill M Member ✭✭
new Flex user…and radio dummy.. here. Where is the RF gain found on an Aurora 510M?
  • K1ESE
    K1ESE Member ✭✭✭
    The short, incomplete answer is to use the AGC-T control as RF-Gain.
    73 de K1ESE
    John
    Hi Bill
    As you are new to FlexRadio, I highly recommend you watch these videos especially the one on AGC-T which replaces RF Gain. Direct Sampling Radio have no requirement for an RF gain control **** the physics is different.
    Even this is 'dated' it is still current.
    Feel free to ask more questions. 73
  • Rick N0VT
    Rick N0VT Member ✭✭✭
    Then what is that setting labeled "RF Gain" under the ANT button for?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    edited July 6
    HIi Rick/Bill.. the RF Gain control under the ANT buttons control the amount of pre-amp gain provided to the Digital-Analog-Converters the antennae are connected to. Kind of like the 'pre-amp' buttons/selections on analog radios. There are various 'stages' of gain to can apply, and there are 'How To' articles here
    "How To" Articles – FlexRadio
    on how to set the amount of RF Gain to apply for each band conditions.
    Hope this helps.
  • Bill M
    Bill M Member ✭✭
    Thanks to all for your help🙏
  • Arnold Goldman
    Arnold Goldman Member ✭✭✭
    Yup i had to ask as well; hold/tap ant1ant2 and theRF gain slider will appear usually i set it to 0 or just 8; good luck
  • VE7ATJ_Don
    Hi Arnold… as I mentioned, there's actually a "how to" article regarding setting the RF Gain for each band/conditions here:
    How to Determine the Correct Amount of RF Preamp Gain for Different Band Conditions – FlexRadio
    It's really good about explaining when and where to use RF Gain.
  • Arnold Goldman
    tnx so much !!
