RF gain?
The short, incomplete answer is to use the AGC-T control as RF-Gain.
73 de K1ESE
John0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Bill
As you are new to FlexRadio, I highly recommend you watch these videos especially the one on AGC-T which replaces RF Gain. Direct Sampling Radio have no requirement for an RF gain control **** the physics is different.
Even this is 'dated' it is still current.
Feel free to ask more questions. 73
Then what is that setting labeled "RF Gain" under the ANT button for?
HIi Rick/Bill.. the RF Gain control under the ANT buttons control the amount of pre-amp gain provided to the Digital-Analog-Converters the antennae are connected to. Kind of like the 'pre-amp' buttons/selections on analog radios. There are various 'stages' of gain to can apply, and there are 'How To' articles here
on how to set the amount of RF Gain to apply for each band conditions.
Hope this helps.
Thanks to all for your help🙏
Yup i had to ask as well; hold/tap ant1ant2 and theRF gain slider will appear usually i set it to 0 or just 8; good luck
Hi Arnold… as I mentioned, there's actually a "how to" article regarding setting the RF Gain for each band/conditions here:
How to Determine the Correct Amount of RF Preamp Gain for Different Band Conditions – FlexRadio
It's really good about explaining when and where to use RF Gain.
tnx so much !!
- 685 The Flea Market
