6400M, problems with update to V.4.2.20
Running Win11 and Smart SDR v.4.2.20, tried to update my radio to newst version. But along the way something went wrong I guess... Frontpanel is still on 4.1.5.39794 and HW version as well.
When running the update everythings seems okay, purple colour on button etc. etc. but nothing is happening when starting up.
Every time when running Smart SDR v.4.2.20 it's saying to 'down grade' to older version.
Followed the instructions when upgrading to latest version (removed programs etc)
Anyone with same issues and how to solve this?
73 Stephan/SM5YRA
    Try this:
    • Update the radio to 4.2.20 from SmartSDR on the PC
    • If it hangs, after about 20 minutes, reboot the radio by removing DC power
    • Restart the radio and connection from the PC using SmartSDR 4.2.20 - it is a different shortcut so you need to look at the name carefully
    • Next, update the Front panel by selecting 4.2.20 to match the radio.
    If you are getting the DownGrade message, that only comes from starting a previous version of SmartSDR.
  • SM5YRA
    SM5YRA Member
    Hi Mike,
    thanks for your quick reply!
    Have tried a lot last couple of days... Uninstalled all SmartSDR, removed all files etc. But not able to update my 6400M to 4.2.20
    Won't bother you with pictures of the 6400M screen, but when starting up everything seems okay. (both with SmartSDR running on Win11 or stand alone)
    But info = Radio firmware 4.2.20.41343
    Operate: still v.4.1.15 when pressing update I got "want to downgrade your radio? v4.2.20 Strange message, should be upgrade. If I choose YES or NO makes any difference.
    When pressing 'YES' same procedure as before: purple button and so on.
    Both Front Panel and Radio HW are still on 4.1.15
    So for some reason the HW and Frontpanel won't upgrade to he new version.
    Any suggestions? Maybe a complete reset of the radio or what to do next...
    Note: lefthand corner "Connect to Ethernet, Internet unavailable" message, but is a bug?
    73 Stephan/SM5YRA
