WSJT Improved with 4.2.2
I have been using VER4.1.5 with mu 6700 and WSJT Improved and the new ver of SliceMaster ver. H I did a complete install of Ver. 4.2.2 …. cold started the 6700 and now CW Skimmer works but WSJT Improved does not…CAT seems to work as I can change bands but the is no audio..looking at the DAX screen it shows no audio and clicking on the buttons does nothing.
What did I moss??
TNX AH)U
Sorry if you are having an issue.
If you haven't had a chance, review the release notes.
https://www.flexradio.com/documentation/smartsdr-v4-2-20-release-notes
SmartSDR v4 Best PracticesBest Practices for Installing SmartSDR
Back Up Your Profiles
Always back up your Global, TX (transmit), and Microphone Profiles before upgrading. For step-by-step export instructions, refer to the SmartSDR for Windows Software User's Guide. It is strongly recommended that you export all profiles before upgrading to version 4.2.20.
Maintaining a current set of exported profiles is a best practice and helps protect against unexpected data loss. Switching between different versions of SmartSDR can result in profile incompatibilities or loss of data if backups are not available.
Update Windows First
Ensure your Windows operating system is up to date before installing SmartSDR for Windows. Proper operation of SmartSDR and its associated drivers depends on a supported and current Windows environment, including up-to-date root security certificates.
Run Windows Update and install all available mandatory and optional updates before installing SmartSDR for Windows.
Power Cycle the Radio Before Installing
Restart the radio before installing the SmartSDR for Windows software on your PC and updating the radio firmware. This helps ensure a smooth and reliable upgrade.
Perform a Cold Boot After Firmware Upgrade
Using the power button, shut down the radio, then disconnect it from DC power. After approximately 30 seconds, reconnect DC power. After restoring DC power, wait at least two minutes before booting the radio. This process ensures a complete reset and helps promote proper operation.
Update All Devices at the Same Time
If using Maestro or other PCs running SmartSDR, update all devices simultaneously to ensure a consistent operating experience and to avoid radio firmware upgrade/downgrade delays.
Always Perform a Factory Reset When Downgrading
Downgrading to a previous version of SmartSDR is not recommended.
The internal database used by Aurora, FLEX-8000, and FLEX-6000 radios is not backward compatible. If a downgrade is required, a Factory Reset is necessary to ensure the radio's internal database aligns properly with the installed firmware version and to prevent potential inconsistencies or operational issues.
If the Radio Is Not Operating Properly After Upgrading
Important: If the radio is not operating properly immediately after upgrading, perform a factory reset and refrain from importing any exported profiles. The database may be inconsistent and require resetting to a default state.
I thought i had mentioned in my post that I had done all that and it does not work with WSJTtnx fer reading my post bc
Have you in WSJTx selected the new DAX channels and are not by mis-chance still using the old ones?
See from minute 9.40 on
Tnx… seem to have it working but the DAX screen is locked out and I can not adjust anything and
it only shows one stream when I have two running
We'd need a screenshot of each slice flag with DAX clicked in the flag to see what DAX channel (if any) are selected.
73 Dave wo2x
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
