zerotier and flex8600 stoped working after 4.2.18 WHY
ZeroTier works but Radio does not respond after update ??????
Confirmed from my side (Flex 8600M, 6600): Having a stable zerotier running, Firmware starting from 3.x.x to 4.1.5, all working fine. Can access and work with Smartsdr on a Flex < 4.2.18.
On any Flexradio with 4.2.18, i can see the Radio remote, i can click on it, its starting up, i can see for a short time the frequency boy/ruler, i see the box "client connected from ip", all as usual. But than i get the error "SmartSDR for Windows has lost connection to the radio. Please reconnect". Smartsdr is closed.
Crosscheck with AetherSdr 26.5.2.1 => No issues. Can see Waterfall, no error.
Crosscheck with Smartsdr 4.1.5 => No issues. Can see Waterfall, no error.
@FlexRadio I can help for searching/hunting the bug when necessary
73 from mike dm5xx0 -
[Tested on Windows 10]0
Mike FYI, The setup and install you did for me this weekend is working perfectly. I use it on my iPhone with both the 8600 and AU520. Version 4.2.18. Windows 11
Thanks for great job.
Tom
N9RU
Tom N9RU
did you conerct direct to 8600? with Iphone not using windows?
try that and report back
/Lars SM4IVE
Lars, yes I connected directly to the iPhone to the 8600 and also to the AU520, both radios on the newest SmartSDR version.
SmartSDR was not running but it works with it running also.
I turned the Wifi off on the phone to be sure it was using the outside network.
This is the first time I have been able to remotely access my Flex radios!
Tom
N9RU
Thanks Lars and Tom, AetherSDR and Marcus Version for IOS seems to make things different - and this still works. Great to see i could help you with it. But Windows User with Zerotier running for months or years will be still doomed, when using 4.2.18 :/
73 de Mike DM5XX0 -
Come on Flex! Lots of us are stuck with CGNAT, with no other real choices. You need to work with Mike to ensure ZeroTier works … assuming you want to sell HW to some of us.
I had to set Fixed IP in Smartsdr for IOS on my Iphone then it worked,
So something in the 4.2.18 are screewd up
I have a bug opened for this: SMART-12837. We are not aware of anything that changed in the network part, but we will look into it. Any further data points would be greatly appreciated.
We may need some very detailed steps on how to recreate this in a lab environment as things like this can be hard to fix when you can't actually capture the problem.
it seems like a good idea for your team to have a ZeroTier RPI set up for testing as quite a few of your customers use it. I am sure Mike would set it up for you with their standard D40 configuration.
- 394 Community Topics
- 671 The Flea Market
- 179 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 83 Aurora
- 323 FLEX-8000 Signature Series
- 983 Maestro
- 957 Genius Products
- 476 Power Genius XL Amplifier
- 350 Tuner Genius XL
- 131 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
