SmartSDR installations on Windows 11
Same problem here, after clicking on install it just quits!
After a third try 3.5.9 installed.
I just installed SSDR on mu NUC PC. Is seems that waterfall works for a moment then quits. Run it in compatibility mode does not help.
Any possible solution to this problem?
Tom
See support ticket 62449. I have a Best Buy off-the-shelf purchased ASUS TUF Gaming laptop. DAX drivers will not install because Core Isolation security feature in Windows 11 prevents it - as designed. If it is disabled to install SmartSDR, it will not re-enable because the drivers are not Microsoft supported. Flex suggests "The current DAX driver is not malicious software ", and "You will need to leave Memory Integrity OFF while using DAX". I find this a totally unacceptable solution. It would also mean I must turn off Core Isolation, reboot, then install SmartSDR every time I want to turn on my Flex radio. Again, I find this totally unacceptable.
When will Flex support Windows 11?0 -
Hello community !
I am a new owner of a flex 6400. Just received a few days ago but have not installed smartSDR yet. I am little concerned with the multiple issues commented here regarding installing the latest version on windows 11. My shack´s PC runs on windows 11. What version of smartSDR should I go with so that installation and operation is smooth?0 -
@eltejada - I would advise that, in addition to the comments received here, that you also open a ticket with the excellent flex support folks and formally ask them the same question. They may have specific steps that will make your Windows 11 experience as smooth as possible.
Please tell us how it all works for you.
Welcome to the platform. I’m sure you will succeed!
At my workplace, I use SmartSDR. I'm about to get a new Win11 PC (yay - Christmas!) and our IT foilks expressly disallow turning-off of these sort of security features (core isolation, memory integrity, address-space layout randomization, etc).
So I will be crossing my fingers that Flex is able to release a new, compatible version of SmartSDR that I can use...
Core isolation fixed for windows 11 yes or no?
My new laptop with Windows 11 pro has huge issues with Flex drivers. I have done everything from turning off Core Isolation and compatabily mode and all cases even when the SmartSDR installed I have no audio or control of power or any functions. This is very dissapointing since my ICOM 9700 remote software loaded with no issues. I did submit a ticket but that was Friday and they don't respond on weekends. I hope they get this fixed before I leave for 2 months in 7 days.
I recently had my new Windows (Dell) computer self destruct. It was a Windows 11 machine. I had not yet upgraded to the new version of SDR when this occurred. I now have a new Windows machines, but It has no versions of SDR on it. Which version (of SCR) should I start with?
Andy WJ8B0 -
Im not having any joy with 3.8.32 using win11 done all Ai can sugest any one got it to work.0
Im only getting conection without waterfall0
Do a trouble ticket, you may have a windows firewall or Network issue problem with it and they may be able to help you sort it out.
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
