Cleaning up old versions of SmartSDR
I (me, not FlexRadio) wrote this script to help remove all copies of SmartSDR which makes it a bit easier than doing it through Add or Remove programs. You still have to use your mouse, but it is a LOT faster. :)
As you can see, I had a few versions on my computer.
I had a bunch to remove.
It should not remove 4.2.18, but I haven't tested that part.
Run it as Admin under Windows Power Shell.
And, if doing this scares you, then you should not do it. :)
$apps = Get-ChildItem "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall",
"HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall" |
ForEach-Object { Get-ItemProperty $_.PSPath } |
Where-Object { $_.DisplayName -like "*SmartSDR*" -and $_.DisplayVersion -ne "4.2.18" } |
Sort-Object DisplayVersion
Write-Host "Will uninstall $($apps.Count) versions..."
$apps | ForEach-Object {
Write-Host "Uninstalling: $($_.DisplayName) $($_.DisplayVersion)"
if ($_.UninstallString -match "msiexec") {
$guid = $_.UninstallString -replace '.*(\{[^}]+\}).*','$1'
Start-Process msiexec.exe -ArgumentList "/x `"$guid`" /qn /norestart" -Wait
} else {
Start-Process $_.UninstallString -Wait
Write-Host "All done."
100% Noob here, only a month into this journey. When you are talking about uninstalling old software I am assuming you mean the SmartSDR software that resides on the computer, and not what is in the Flex Radio itself. Is that correct?0
Yes, just the client software on the computer, not the server software on the radio.
I believe the radio side of SmartSDR is updated as part of the install process. There are deeper layers of software in the Flex radio box that are not touched by SmartSDR, so are not affected by the update.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 114 Aurora
- 980 Genius Products
- 359 Tuner Genius XL
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
- 486 Remote Operation (SmartLink)
- 848 Peripherals & Station Integration
