no streming DAX v.4.2
You need to use it in a program like MMTTY. Then it will turn green and you will see level. This must be a change in the new DAX, Experts please comment.
There's no way with SDR Bridge. I spoke to Ed W2RF who will try to make some changes.
Hi Guys, i had the same issue. i set up a new PC with win11. completly new. everything runs ok, only dax was not working. i found that if i put in my log program (UCX log) a receive channel in the soundcard tab, the channel maybe DAXRX1 was streaming. If i change to DAXIQ1, What makes no sense for the logprogram, the skimmer works, also the mtty machine runs. So for me it seem that the DAX is only streaming if a secondary program calls the channel from DAX. But that did not work with mtty and cw skimmer. Maybe that could be a hint. Mikel, DL9eca0
I downgraded to 4.1.5 and everything works again with sdrBridge and slicemaster, especially AetherSDR.
Just like to add my penny worth that i am having problem with my mic input reading on dax shows nothing but when i put into data mode it works with my data programs in win 11 just cant get my mic input to work so i dont know whats happening?
not sure I understand he situation very well, but DAX is Digital Audio Exchange, digital audio only. Not used with Mic audio.
I was talking about the mic stream as i get no meter reading on that one but when i use for data like sstv/rtty/varac the meters work for all of the other meters for data
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 217 DAX
- 391 SmartSDR API
- 87 Aurora
- 332 FLEX-8000 Signature Series
- 988 Maestro
- 960 Genius Products
- 351 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
- 844 Peripherals & Station Integration
