4.2.18 Dax
Should I be able to see DAX and VSP somewhere in the Win 11 Installed Apps list? Can only find SmartSDR Ver 4.2.18 listed.
No they are part of the SmartSDR app.
Note the required changes needed to digital mode programs so that they work with DAXv2.
Streaming on DAX RX will not be present if there is not any incoming data. Check your digital program, example WSJTx, that you have accurately changed the Input to DAX RX1. TX may work even if you have not made the required change per the Flex instructions but still make the change to DAX TX.
I did not realize the icon now followed the connection state to the application. I had the input source set to IQ 1. All is well now..
Thanks.
I dont even have a radio, 8600 not arrived yet, I was just looking for the new downloaded App(s) on the PC :)
I have already set the required DAX input/output audio streams in WSJT and JTDX so bring on the 8600
Thank you Eric EI4KF for the "reminder".
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
