4.2.18 Dax
Should I be able to see DAX and VSP somewhere in the Win 11 Installed Apps list? Can only find SmartSDR Ver 4.2.18 listed.
No they are part of the SmartSDR app.
Note the required changes needed to digital mode programs so that they work with DAXv2.
Streaming on DAX RX will not be present if there is not any incoming data. Check your digital program, example WSJTx, that you have accurately changed the Input to DAX RX1. TX may work even if you have not made the required change per the Flex instructions but still make the change to DAX TX.
I did not realize the icon now followed the connection state to the application. I had the input source set to IQ 1. All is well now..
Thanks.
I dont even have a radio, 8600 not arrived yet, I was just looking for the new downloaded App(s) on the PC :)
I have already set the required DAX input/output audio streams in WSJT and JTDX so bring on the 8600
Thank you Eric EI4KF for the "reminder".
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
