Maestro battery discharges after 1 or 2 days even when off
This issue was accompanied with non graceful shutdown. Has anyone seen this problem?
https://www.youtube.com/shorts/y5WiYlLP1cQ
Has anyone encountered this issue? I have to take the battery out every time I am done using it or the battery will flatline within a day or two.
OM Chris,
I suggest to charge the battery fully and leave it not connected to Maestro and after a few days check it it keeps charge. If it does, it means the fault is within Maestro, not battery.
Contact Flex for advice.
Tom
Hello Tom,
That is exactly what happens. Full charge and unplug charger. Even with battery removed and reinstalled. It isthe same thing.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIs this a genuine RRC battery? Or, a clone?
I bought the original with the unit from WIMO. The Red led stays on inside the unit. https://www.youtube.com/shorts/y5WiYlLP1cQ
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
