Maestro battery discharges after 1 or 2 days even when off
This issue was accompanied with non graceful shutdown. Has anyone seen this problem?
https://www.youtube.com/shorts/y5WiYlLP1cQ
Has anyone encountered this issue? I have to take the battery out every time I am done using it or the battery will flatline within a day or two.
OM Chris,
I suggest to charge the battery fully and leave it not connected to Maestro and after a few days check it it keeps charge. If it does, it means the fault is within Maestro, not battery.
Contact Flex for advice.
Tom
Hello Tom,
That is exactly what happens. Full charge and unplug charger. Even with battery removed and reinstalled. It isthe same thing.
Is this a genuine RRC battery? Or, a clone?
I bought the original with the unit from WIMO. The Red led stays on inside the unit. https://www.youtube.com/shorts/y5WiYlLP1cQ
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 321 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
