S.A.T Self-contained Antenna Tracker
Those of you using a 6600 with vhf and uhf transverters - has anyone used the S.A.T Satellite Antenna Tracker from CSN Technologies —
It's designed to control ICOM rigs, but it will work with a Yeasu AZ/EL rotator to track the birds. I don't think it needs to be connected to the radio to work. From what I see, it merely controls the frequency setting on the radio.
If it works as advertised, it would reduce the amount of rotator tuning needed to keep a bird in range.
The CSN S.A.T device will not interface with a Flex Radio.
I provided CSN with a easy to implement method to interface with Flex and they have so far not added same to their firmware.
Alan. WA9WUD
I recently asked CSN Technologies about SAT support they said their latest firmware is supposed to work with Flex radios via TCP/IP wanted to see if anyone has any recent experience with the device?
In our last update, we have added Support for flex radios I’m not familiar with the radios that you’ve listed so I’m not sure which Radio versions it actually works with.If it is a current flex, Radio, the SAT will control it over the network.MikeSent from my iPhone
On Apr 18, 2026, at 5:30 PM, info <info@igatemini.com> wrote:From n3ick@cox.net Callsign: n3ickAre there any plans to add CAT control via TCP/IP for the Flex Radio 6xxx 8xxx and AU-520 transceivers?Thanks
The S.A.T works with the Flex over TCP. The device creates two new pan adapters and two new slices, which can be disruptive to a four slice configuration.
Alan. WA9WUD
Alan and I have been using it for Months. It works great, but it is a bit does totally take over all the radio when you are tracking a satellite.
But, I do love it!
Mike va3mw
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
