BaudRate Sdr Cat
IK8HCG
in SmartSDR CAT
where do you change the Baud Rate 4800-9600 etc. in smardSdr Cat?
tnx, lou IK8HCG
There is no requirement. It will 'autobaud'. It does work.
Lou,
Unless you are configuring an 'Existing' hardware comport on your PC to work with SSDR CAT, there is no need to set Baud Rate. The data is never serialized but passes as parallel bytes from the SSDR CAT app to your user app.
If you need to connect external hardware to the PC and SSDR CAT, then you would configure an 'Existing' hardware comport which then includes Baud rate, etc.
AL, K0VM
Tnx, both
so if I want to change the data flow I act on the satellite program?
- 384 Community Topics
- 649 The Flea Market
- 149 SmartSDR+
- 263 SmartSDR CAT
- 287 FLEX-8000 Signature Series
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
