BaudRate Sdr Cat
IK8HCG
in SmartSDR CAT
where do you change the Baud Rate 4800-9600 etc. in smardSdr Cat?
tnx, lou IK8HCG
There is no requirement. It will 'autobaud'. It does work.
Lou,
Unless you are configuring an 'Existing' hardware comport on your PC to work with SSDR CAT, there is no need to set Baud Rate. The data is never serialized but passes as parallel bytes from the SSDR CAT app to your user app.
If you need to connect external hardware to the PC and SSDR CAT, then you would configure an 'Existing' hardware comport which then includes Baud rate, etc.
AL, K0VM
Tnx, both
so if I want to change the data flow I act on the satellite program?
Which Satellite program?
Set the baud rate in the satellite program and CAT will figure it out.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
