BaudRate Sdr Cat
IK8HCG
in SmartSDR CAT
where do you change the Baud Rate 4800-9600 etc. in smardSdr Cat?
tnx, lou IK8HCG
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThere is no requirement. It will 'autobaud'. It does work.
Lou,
Unless you are configuring an 'Existing' hardware comport on your PC to work with SSDR CAT, there is no need to set Baud Rate. The data is never serialized but passes as parallel bytes from the SSDR CAT app to your user app.
If you need to connect external hardware to the PC and SSDR CAT, then you would configure an 'Existing' hardware comport which then includes Baud rate, etc.
AL, K0VM
Tnx, both
so if I want to change the data flow I act on the satellite program?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWhich Satellite program?
Set the baud rate in the satellite program and CAT will figure it out.
- 322 Shack Infrastructure
- 227 Networking
