SmartCAT will noty start
Hi all
I have configured SmartSDR (ver 4.0.1on a Win 10 PC) to automatically launch SmartCAT when started.
Quite often, SmartCAT will not start, and when it does, it does not work properly quite often too. .
Any idea how to fix that ?
In other words, should I reinstall Smart SDR, and if so, can I reinstall on top of the existing one, so as not to loose the setup ?
Should I install the latest version, instead of reinstalling v4.0.1 ?
TU + 73
Paul F6EXV
Hi Paul, I would just install 4.1.5. There is no need to uninstall the old one. Export your profiles first
Hi again
Thanks Len.
I did download and install v4.1.5 without any issue….BUT when I am trying to launch JTDX, I get an error message regarding an "entry point procedure clock_gettime64 that cannot be fouund in the dynamic links library C:\JTDX64\FLEX\bin\libhamlib-4.dll"
MSHV and WSJT won't work either…
Another issue (maybe it is not) : on the DSP, in CW mode, the NRL option is greyed out, in SSB NRL ANFL ANFT are greyed out, in DIGU, the NRL is greyed out. Is this normal ?
How can I solve that ?
TU + 73
Paul F6EXV
Hi Paul, did you purchase SmartSDR+? If not, that is why the controls are grayed out.
The JTDX issue may be solved by doing a factory reset (after exporting profiles).
Len
No, no SmartSDR+… I did a factory reset
I did a factory reset, and once again, Spmart CAT won' start, not even with the shortcul created by the installation. When I solve a problem, it creates another issue, when I solve this new issue, the old problem comes back.
Now the clock_gettime64 issue is appearing again. Back to square 1…
Quite annoying…
Next step please ?
Paul, you need to open a support ticket. It will be much faster to get it resolved. They respond pretty fast.
I do not know why and how, but it now seams to work !
Another mystery ! La vie est belle !
73 and Season's Greetings to all !
Paul F6EXV
La vie n'est pas belle ! Problem shows again… Starting SmardSDR will start SmartDAX but will not start SmartCAT.
Kind of getting fed up…
Help ticket sent… KMFC
I opened a support ticket in December, no news as of today… They are supposed to contact me direct, but no email received… What is going on ?
I did receive the email confirlming the support ticket was opened, but since then, nothing…
Quite unhappy…
When you opened a ticket, did you get an email with a ticket number? If not, then check your spam and if no luck there, open a new ticket.
I did get that email , but then nothing…
I'll paste the reply here
Hi Ken
Thanks for that reply.
I just wonder where that was sent to , Definitively not to me direct….
So I'll just wait for the fix…
Paul F6EXV
It went to the email address you opened the ticket under. Your hotmail address. The email was sent.
Hi Mike
Well, I did not receiove it, but what matters is that I have the answer !
Thanks again
73 + TU
Paul F6EXV
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
