SmartCAT will noty start
Hi all
I have configured SmartSDR (ver 4.0.1on a Win 10 PC) to automatically launch SmartCAT when started.
Quite often, SmartCAT will not start, and when it does, it does not work properly quite often too. .
Any idea how to fix that ?
In other words, should I reinstall Smart SDR, and if so, can I reinstall on top of the existing one, so as not to loose the setup ?
Should I install the latest version, instead of reinstalling v4.0.1 ?
TU + 73
Paul F6EXV
Hi Paul, I would just install 4.1.5. There is no need to uninstall the old one. Export your profiles first
Hi again
Thanks Len.
I did download and install v4.1.5 without any issue….BUT when I am trying to launch JTDX, I get an error message regarding an "entry point procedure clock_gettime64 that cannot be fouund in the dynamic links library C:\JTDX64\FLEX\bin\libhamlib-4.dll"
MSHV and WSJT won't work either…
Another issue (maybe it is not) : on the DSP, in CW mode, the NRL option is greyed out, in SSB NRL ANFL ANFT are greyed out, in DIGU, the NRL is greyed out. Is this normal ?
How can I solve that ?
TU + 73
Paul F6EXV
Hi Paul, did you purchase SmartSDR+? If not, that is why the controls are grayed out.
The JTDX issue may be solved by doing a factory reset (after exporting profiles).
Len
No, no SmartSDR+… I did a factory reset
I did a factory reset, and once again, Spmart CAT won' start, not even with the shortcul created by the installation. When I solve a problem, it creates another issue, when I solve this new issue, the old problem comes back.
Now the clock_gettime64 issue is appearing again. Back to square 1…
Quite annoying…
Next step please ?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsPaul, you need to open a support ticket. It will be much faster to get it resolved. They respond pretty fast.
I do not know why and how, but it now seams to work !
Another mystery ! La vie est belle !
73 and Season's Greetings to all !
Paul F6EXV
La vie n'est pas belle ! Problem shows again… Starting SmardSDR will start SmartDAX but will not start SmartCAT.
Kind of getting fed up…
Help ticket sent… KMFC
I opened a support ticket in December, no news as of today… They are supposed to contact me direct, but no email received… What is going on ?
I did receive the email confirlming the support ticket was opened, but since then, nothing…
Quite unhappy…
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWhen you opened a ticket, did you get an email with a ticket number? If not, then check your spam and if no luck there, open a new ticket.
I did get that email , but then nothing…
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI'll paste the reply here
Hi Ken
Thanks for that reply.
I just wonder where that was sent to , Definitively not to me direct….
So I'll just wait for the fix…
Paul F6EXV
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt went to the email address you opened the ticket under. Your hotmail address. The email was sent.
Hi Mike
Well, I did not receiove it, but what matters is that I have the answer !
Thanks again
73 + TU
Paul F6EXV
