Profiles and USB Bit Cable?
Geoff AB6BT
Member ✭✭✭
Can a profile be used to send data via a USB cable?
For example, can a profile be used to send data to select an antenna using external hardware?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsProfile? I don't think so. The Bit cable triggers are global and external to the profiles.
Darn…
what are you trying to do Geoff?
Hi Dave…Well, what I was thinking is to be able to switch antennas based on a profile. I use a 40M wire dipole for most local contacke but I use the 40M rotatable dipole on my C4 for other contacts. It would be convenient to have the antennas switched based on a profile.
CurrentlyI have a mechanical coax switch that I use which works fine.
I could build an interface for an old Drake RCS-4 that I have to do the switching.
Just thinking…
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
