Profiles and USB Bit Cable?
Can a profile be used to send data via a USB cable?
For example, can a profile be used to send data to select an antenna using external hardware?
    Profile? I don't think so. The Bit cable triggers are global and external to the profiles.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Darn…
  • David Decoons, wo2x
    what are you trying to do Geoff?
  • Geoff AB6BT
    Hi Dave…Well, what I was thinking is to be able to switch antennas based on a profile. I use a 40M wire dipole for most local contacke but I use the 40M rotatable dipole on my C4 for other contacts. It would be convenient to have the antennas switched based on a profile.
    CurrentlyI have a mechanical coax switch that I use which works fine.
    I could build an interface for an old Drake RCS-4 that I have to do the switching.
    Just thinking…
