DVK works great on Maestro but can’t save recordings to Function Keys
On my Maestro C I can chose DVK for the Functions buttons but when the second dropdown menu appears, there are no dropdowns to pick which DVK to tag to that Function key. Is this aspect of DVK not activated yet in V4.01? I am a paid Flex SmartSDR+ Early Access subscriber.
Hi John, I think that there is a form or something that you need to fill out. I am not an Early Access purchaser, so not quite sure what the protocol is.
I notice that I have you in my log a couple of times on 40 SSB. Look forward to hearing you on the air again.
EA subscriber in UK has this on his 8600M but same as you on his separate Maestro ie no function key tags.
I have cold rebooted the radio and still no joy. DVK works but I can’t assign the recordings to F keys on the Maestro as they won’t show up in the second dropdown menu.
Well glad to hear that I am not alone with my 6600M.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsCan you test on 4.1.3 please and make sure you also reset the radio. thanks
On my 8400M, I can assign DVK recordings to the F keys but on the next boot they have disappeared. They are still in SSDR (4.1.3) and working from there and so I have a radio issue. I have tried a factory reset.
I've opened a ticket on 4.2.20. I'm also running SmartSDR+ on my Maestro-C and can't assign any DVK Playback recordings to Function F1-F6 keys . The drop down box is empty.
Flexradio Helpdesk provided this response:
- Defect Tracking Number: SMART-12805 Maestro Does Not Display the DVK Recordings in Function Key Menu over SmartLink
- Current Status: Under Engineering Investigation
- Workaround: Unfortunately, there are no known workarounds available at this time.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
