DVK works great on Maestro but can’t save recordings to Function Keys
NG0Z
NG0Z Member ✭✭
On my Maestro C I can chose DVK for the Functions buttons but when the second dropdown menu appears, there are no dropdowns to pick which DVK to tag to that Function key. Is this aspect of DVK not activated yet in V4.01? I am a paid Flex SmartSDR+ Early Access subscriber.
    edited November 2
    Hi John, I think that there is a form or something that you need to fill out. I am not an Early Access purchaser, so not quite sure what the protocol is.
    I notice that I have you in my log a couple of times on 40 SSB. Look forward to hearing you on the air again.
  • Erik Carling EI4KF
    EA subscriber in UK has this on his 8600M but same as you on his separate Maestro ie no function key tags.
  • NG0Z
    NG0Z Member ✭✭
    I have cold rebooted the radio and still no joy. DVK works but I can’t assign the recordings to F keys on the Maestro as they won’t show up in the second dropdown menu.
  • VE3DZP
    VE3DZP Member ✭✭
    Well glad to hear that I am not alone with my 6600M.
    Can you test on 4.1.3 please and make sure you also reset the radio. thanks
    On my 8400M, I can assign DVK recordings to the F keys but on the next boot they have disappeared. They are still in SSDR (4.1.3) and working from there and so I have a radio issue. I have tried a factory reset.
