My 6400M cutting out on tx with amp connected
jim
Member ✭
Hi folks, I have a 6400M running to a resonant dipole about 40' up, powering through an ACOM 1500 Linear amp and a Palstar HF-Auto tuner. This is a new issue. Radio runs fine at 100W without the amp. Once I connect amp 6400m shuts down. I've checked power from the DM-330MV Alinco supply and no issues, I've changed out amps (tried both my Al-80B's- no luck- still shuts down), I've checked all patch cables. SWR is showing 1.02 to 1.05 at tuner. running version 4.0.1 on flex. I also have another 6400M and same issue. (runs fine at 100W but shuts down once amp is keyed). I have ferrites on most cables. Also have an MFJ 915 1:1 Current Balun on feed line to antenna.
Can't figure it out. Any ideas or suggestions?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt sounds like you need some RF chokes on the power lines, coax cables and LAN cables.
This document helps explain it.
I agree with Mike, and will add USB cables to the PC as a potential source of problems. Also add ferrites to LAN cables that are not used for your radio - they can be the cause as well.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsBob at Palomar sells some great choke kits
thanks Mike, I'll check them out0
