SDC Skimmer & 3.10.10
Can someone test SDC Skimmer on 3.10.10 please. We have a few people saying it does not work as expected.
Many thanks
Hi Mike,
I have had a message from Yuri UT4LW confirming that there is an issue with 3.10.10 not sending IQ data and that he has emailed Flex about it. Reverting to 3.9.19 resolves the issue.
73, Jonathan G4IVV
Try the 3.9.19 DAX and see if that resolves it. You can safely do that.
Hi Mike,
SDC does not use DAX, it talks directly to the Flex TCP and UDP API endpoints.
Jonathan
You learn something every day. Thanks for sharing. I must have missed the fine print on that. :)
Hi Michael
In version 3.10.10 there was a change in the UDP-IQ stream that was incompatible with SDC. I had a conversation with the developers and they informed me that there will be an update of the transceiver program.
I can make changes to SDC to be compatible with these changes, but there are other issues that have occurred in the new version that need to be addressed. Therefore, I cannot recommend 3.10.10 to work with SDC.
An update for everyone. A number of us have been getting to the bottom of this including Yuri. We have a working version of SmartSDR that returns SDC to a working condition. Right now it is tagged in 4.01 (or similar). No exact date just yet, but hopefully not too long. It still has to go through a few internal processes.
Thanks for the update Mike. The SDC Skimmer is sooo cool and I really miss it!
Does this mean the fix will NOT be in a 3.x release?
73, Pat KØPC
version 4 is the very next release as the release notes said for 3.10.15 and EVERY ONE will need to move to Ver 4 and won't cost anyone BUT they will only have the features turned on that the they have now. This means Flex won't have version 1, 2 and 3 anymore to maintain, and is a VERY GOOD THING in my opinion.
Correct. 4.x Basic is an extension of 3 but with a move to the new licensing platform.
Thanks, I didn't read the subscription announcement close enough last month to pick up that everyone can move to 4.0 as a new starting point.
I think a number of people might have read it that way. :)
Everyone gets v4-basic for free.
SDC problem continuo also in 3.10.15
I do confirm 4.0.1 resolves the issue introduced in 3.10.10
SDC is back !
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
