SDC Skimmer & 3.10.10
Mike-VA3MW
Can someone test SDC Skimmer on 3.10.10 please. We have a few people saying it does not work as expected.
Many thanks
  • g4ivv
    g4ivv Member ✭✭
    Hi Mike,
    I have had a message from Yuri UT4LW confirming that there is an issue with 3.10.10 not sending IQ data and that he has emailed Flex about it. Reverting to 3.9.19 resolves the issue.
    73, Jonathan G4IVV
    Try the 3.9.19 DAX and see if that resolves it. You can safely do that.
  • g4ivv
    g4ivv Member ✭✭
    Hi Mike,
    SDC does not use DAX, it talks directly to the Flex TCP and UDP API endpoints.
    Jonathan
    You learn something every day. Thanks for sharing. I must have missed the fine print on that. :)
  • UT4LW
    UT4LW Member ✭✭
    Hi Michael
    In version 3.10.10 there was a change in the UDP-IQ stream that was incompatible with SDC. I had a conversation with the developers and they informed me that there will be an update of the transceiver program.
    I can make changes to SDC to be compatible with these changes, but there are other issues that have occurred in the new version that need to be addressed. Therefore, I cannot recommend 3.10.10 to work with SDC.
    An update for everyone. A number of us have been getting to the bottom of this including Yuri. We have a working version of SmartSDR that returns SDC to a working condition. Right now it is tagged in 4.01 (or similar). No exact date just yet, but hopefully not too long. It still has to go through a few internal processes.
    Thanks for the update Mike. The SDC Skimmer is sooo cool and I really miss it!
  • Pat KØPC
    Pat KØPC Member ✭✭
    Does this mean the fix will NOT be in a 3.x release?
    73, Pat KØPC
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited October 2025
    version 4 is the very next release as the release notes said for 3.10.15 and EVERY ONE will need to move to Ver 4 and won't cost anyone BUT they will only have the features turned on that the they have now. This means Flex won't have version 1, 2 and 3 anymore to maintain, and is a VERY GOOD THING in my opinion.
    @Pat KØPC
    Correct. 4.x Basic is an extension of 3 but with a move to the new licensing platform.
  • Pat KØPC
    Pat KØPC Member ✭✭
    edited October 2025
    Thanks, I didn't read the subscription announcement close enough last month to pick up that everyone can move to 4.0 as a new starting point.
    I think a number of people might have read it that way. :)
    Everyone gets v4-basic for free.
  • iz7auh
    iz7auh Member ✭✭✭
    SDC problem continuo also in 3.10.15
  • F4BPO
    F4BPO Member ✭✭
    I do confirm 4.0.1 resolves the issue introduced in 3.10.10
    SDC is back !
