Editing Profile "Owned"
How can I change which products I own at the bottom of my profile?
If I select "Edit Profile" there is no provision to do so.
Can you explain more? Where are you seeing this?
At the bottom of my Profile:
Mike…Do you need more info from me?
Hi Geoff… if it's any consolation, I asked the same question about a year or so ago when I switched to a 6700 and got no response either. There doesn't appear to be any way to edit/update 'Products owned' after the initial account setup.
I have no idea where that data comes from. It isn't in your profile, as I looked for something that sets it.
Don…OK, well I guess it is some consolation. At least 2 of us have asked.
Mike…Should I give up?
Hi Mike… when you register, it's the 4th box down.
I understand that it's not in our profile .
I wonder where it's stored cuz it shows up as Geoff showed, when you look at 'About Me'.
It has to be in the database somewhere, I wonder who decided it should not be editable or why?
Clearly equipment owned changes over time.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
