Editing Profile "Owned"
How can I change which products I own at the bottom of my profile?
If I select "Edit Profile" there is no provision to do so.
    Can you explain more? Where are you seeing this?
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    At the bottom of my Profile:
  • Geoff AB6BT
    Mike…Do you need more info from me?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    edited September 2025
    Hi Geoff… if it's any consolation, I asked the same question about a year or so ago when I switched to a 6700 and got no response either. There doesn't appear to be any way to edit/update 'Products owned' after the initial account setup.
    I have no idea where that data comes from. It isn't in your profile, as I looked for something that sets it.
  • Geoff AB6BT
    Don…OK, well I guess it is some consolation. At least 2 of us have asked.
    Mike…Should I give up?
  • VE7ATJ_Don
    Hi Mike… when you register, it's the 4th box down.
    I understand that it's not in our profile .
    I wonder where it's stored cuz it shows up as Geoff showed, when you look at 'About Me'.
  • Geoff AB6BT
    It has to be in the database somewhere, I wonder who decided it should not be editable or why?
    Clearly equipment owned changes over time.
