8 Slices numerous IP delays VIDEO
Please watch the entire SHORT.
I am getting numerous errors when I try and run 8 slices on my 6700 that never had these issues. I'm running a i9 64gb computer that previously had no trouble running 8 slices.
This is occurring with 3.10.10 and the previous 2 versions. The flex runs thru a 8 connection switch that has just been replaced thinking it was the problem.
Running only 4 slices all is normal is it something in these latest updates that no longer lets the 6700 run all 8 slices with a fast bootup?
Ian
km4cqg
The short was edited and the 1st 2 min of this removed.
It looks like the devices at 1.43, 1.46 and 1.45 are repeatedly connecting to the radio. Do you know which devices those are?
They are the 403 Tuner 403 Antenna Genius and the PGXL.
If you run 4 slices it all works great as it always has just not with 8 Slices.
Ian
This sounds like something that you should bring to 4O3A's attention.
Are you using SliceMaster at the same time? Does it go away if you terminate slicemaster?
Slice master on or off doesn't change anything.
Even if I don't run the apps to control the PGXL, SO2R Tuner genius or the Antenna Genius the problem still persist.
The integration works flawless as it always has for 4 slices. But running 8 causes the issue.
Some may wonder why 8 Slices. I utilize WSPR and PSK as well as FT8 and FT4.
Been trying to earn 5 Band DXCC and Honor Roll
Ian
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 390 SmartSDR API
- 87 Aurora
- 328 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
