8 Slices numerous IP delays VIDEO
https://youtube.com/shorts/neaownpSuAY?si=f9-Nti_g6uMEBoxN
Please watch the entire SHORT.
I am getting numerous errors when I try and run 8 slices on my 6700 that never had these issues. I'm running a i9 64gb computer that previously had no trouble running 8 slices.
This is occurring with 3.10.10 and the previous 2 versions. The flex runs thru a 8 connection switch that has just been replaced thinking it was the problem.
Running only 4 slices all is normal is it something in these latest updates that no longer lets the 6700 run all 8 slices with a fast bootup?
Ian
km4cqg
  • KM4CQG
    KM4CQG Member ✭✭
    The short was edited and the 1st 2 min of this removed.
  • Eric-KE5DTO
    It looks like the devices at 1.43, 1.46 and 1.45 are repeatedly connecting to the radio. Do you know which devices those are?
  • KM4CQG
    KM4CQG Member ✭✭
    They are the 403 Tuner 403 Antenna Genius and the PGXL.
    If you run 4 slices it all works great as it always has just not with 8 Slices.
    Ian
  • Eric-KE5DTO
    This sounds like something that you should bring to 4O3A's attention.
    Are you using SliceMaster at the same time? Does it go away if you terminate slicemaster?
  • KM4CQG
    KM4CQG Member ✭✭
    Slice master on or off doesn't change anything.
    Even if I don't run the apps to control the PGXL, SO2R Tuner genius or the Antenna Genius the problem still persist.
    The integration works flawless as it always has for 4 slices. But running 8 causes the issue.
    Some may wonder why 8 Slices. I utilize WSPR and PSK as well as FT8 and FT4.
    Been trying to earn 5 Band DXCC and Honor Roll
    Ian
