SDC Skimmer & 3.10.10
Can someone test SDC Skimmer on 3.10.10 please. We have a few people saying it does not work as expected.
Many thanks
Hi Mike,
I have had a message from Yuri UT4LW confirming that there is an issue with 3.10.10 not sending IQ data and that he has emailed Flex about it. Reverting to 3.9.19 resolves the issue.
73, Jonathan G4IVV
Try the 3.9.19 DAX and see if that resolves it. You can safely do that.
Hi Mike,
SDC does not use DAX, it talks directly to the Flex TCP and UDP API endpoints.
Jonathan
You learn something every day. Thanks for sharing. I must have missed the fine print on that. :)
Hi Michael
In version 3.10.10 there was a change in the UDP-IQ stream that was incompatible with SDC. I had a conversation with the developers and they informed me that there will be an update of the transceiver program.
I can make changes to SDC to be compatible with these changes, but there are other issues that have occurred in the new version that need to be addressed. Therefore, I cannot recommend 3.10.10 to work with SDC.
2
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 211 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
