Confused about mic and Marstro C
W2PP
W2PP Member ✭✭✭
just received my C today. Looks great. So I ordered the FHM3 but unlike my old B model I don’t see a place to plug it in. I ordered the Y cable and thought that was somehow what I needed.
How do I attach a microphone to the C model?
Thanks in advance
Peter
  • David Decoons, wo2x
    the Y cable kit has a Y cable with TRRS that plugs into the CTIA connector on Maestro. Mic plug goes into the mic side of Y cable.
    There is an RCA female to TS 3.5mm male adapter. Mic PTT to the adapter and adapter to PTT in on Maestro.
  • W2PP
    W2PP Member ✭✭✭
    the mic has an rj45 connector on it
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    edited May 2024
    I have that same FHM3 variant (with RJ45) which I used with my Maestro B. I am waiting for the appearance of a new mic-cable, which I can plug directly into the microphone, and the other end has two Maestro C plugs.
    I lose adapters. They get noisy and intermittent. I don't want adapters.
  • Arnold Goldman
    Arnold Goldman Member ✭✭
    look at the k5ebq comments below it took me several hours as well to figure it out; the headset connector stays disconnected; i also like the mic connector on the B MUCH BETTER they should have made an adapter
  • W2PP
    W2PP Member ✭✭✭
    edited May 2024
    I wonder if my Heil Pro 7 headset will work?
    I should send out the Maestro C FAQ again. :)
    Mics with TS (Mono) Microphone connectors
    Microphones with a TS ⅛” Microphone connector (such as Heil ProSets) may not work correctly with the Y adapter cable.
    The Y cable requires a TRS ⅛” connector with the Mic + on Tip and the Mic - (or ground) on the Shield.
    Heil has advised us they are working on a solution, so you may want to reach out to Heil directly.
    PTT and Headset Breakout Kit (MAE-C-Adapter)
    If you wish to use the FLEX-6400 or FLEX-6600  FHM-3 Hand Mic or the Inrad desk Mic with a Maestro C, you will need this kit.
    The kit includes the RCA to ⅛” TS Mono adapter to connect a Footswitch with an RCA connector such as the Radiosport Footswitch.
    It also included a Headset Y adapter that splits the Headset TRRS jack on the Maestro to a ⅛” TRS for the Microphone and a ⅛” TRS for a typical stereo Headset.
    When using the FHM-3 and the Y cable:
    • M-HDST selected on the Maestro C
    • BIAS turned on in the Phone/CW settings
    • USB or LSB mode
    • TX DAX turned off
    These 2 items are a must-have with your Maestro C.
    https://www.flexradio.com/products/maestro-c-y-cable-kit/
  • W2PP
    W2PP Member ✭✭✭
    thx Mike. I’ll just order a new microphone. I found it after noodling around a bit tho morning
    Mike o didn’t get any screws to attach the base. I can get them locally can you tell me their specs?
    Peter
    We can ship you some right away.
    I think they are M4's
  • W2PP
    W2PP Member ✭✭✭
    ok please do
  • W2PP
    W2PP Member ✭✭✭
    I’m going to order a battery pack and mic too
  • W2PP
    W2PP Member ✭✭✭
    ok just placed the order. Can they add them to that?
  • W2PP
    W2PP Member ✭✭✭
    Were you able to get the screws in my shipment?
    Peter
  • Tom AB8RL
    Tom AB8RL Member
    The PTT button on FH3 won’t key the Maestro C? Must you use an external keying device like a foot switch external switch? Or if I get the Y cable and new microphone that’s all I need?
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    The Y cable includes an adapter that allows plugging the mic’s PTT lead into the Maestro C’s PTT socket.
