Confused about mic and Marstro C
the Y cable kit has a Y cable with TRRS that plugs into the CTIA connector on Maestro. Mic plug goes into the mic side of Y cable.
There is an RCA female to TS 3.5mm male adapter. Mic PTT to the adapter and adapter to PTT in on Maestro.
the mic has an rj45 connector on it
I have that same FHM3 variant (with RJ45) which I used with my Maestro B. I am waiting for the appearance of a new mic-cable, which I can plug directly into the microphone, and the other end has two Maestro C plugs.
I lose adapters. They get noisy and intermittent. I don't want adapters.
look at the k5ebq comments below it took me several hours as well to figure it out; the headset connector stays disconnected; i also like the mic connector on the B MUCH BETTER they should have made an adapter
I wonder if my Heil Pro 7 headset will work?
I should send out the Maestro C FAQ again. :)
Mics with TS (Mono) Microphone connectors
Microphones with a TS ⅛” Microphone connector (such as Heil ProSets) may not work correctly with the Y adapter cable.
The Y cable requires a TRS ⅛” connector with the Mic + on Tip and the Mic - (or ground) on the Shield.
Heil has advised us they are working on a solution, so you may want to reach out to Heil directly.
PTT and Headset Breakout Kit (MAE-C-Adapter)
If you wish to use the FLEX-6400 or FLEX-6600 FHM-3 Hand Mic or the Inrad desk Mic with a Maestro C, you will need this kit.
The kit includes the RCA to ⅛” TS Mono adapter to connect a Footswitch with an RCA connector such as the Radiosport Footswitch.
It also included a Headset Y adapter that splits the Headset TRRS jack on the Maestro to a ⅛” TRS for the Microphone and a ⅛” TRS for a typical stereo Headset.
When using the FHM-3 and the Y cable:
- M-HDST selected on the Maestro C
- BIAS turned on in the Phone/CW settings
- USB or LSB mode
- TX DAX turned off
These 2 items are a must-have with your Maestro C.
thx Mike. I’ll just order a new microphone. I found it after noodling around a bit tho morning
Mike o didn’t get any screws to attach the base. I can get them locally can you tell me their specs?
Peter0 -
We can ship you some right away.
I think they are M4's
ok please do
I’m going to order a battery pack and mic too
ok just placed the order. Can they add them to that?
Were you able to get the screws in my shipment?
Peter
The PTT button on FH3 won’t key the Maestro C? Must you use an external keying device like a foot switch external switch? Or if I get the Y cable and new microphone that’s all I need?0
The Y cable includes an adapter that allows plugging the mic’s PTT lead into the Maestro C’s PTT socket.
2
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
