Slice Master does not keep settings
I experimenting with Slice Master to start 2 instances of JTDX.
It works after initial setting, but after closing and opening again it reset Radio from Flex to HRD and changes Network Server. I cannot find in Slice Master any default settings. Maybe someone can point me to a right direction?
Here is the screenshot - original setting and what it resetting it to after reopening.
Sergey, KN7K
Hi Sergey
Just email Don directly and let him know.
M
Hi Sergey,
What you are seeing is the intended behavior. When you ask Slice Master to launch JTDX for you, it will configure the rig control settings and the audio device setting for you according to slice you have selected at launch time. Ham Radio Deluxe is correct here. There's no need to change it.
If you'd like to change other settings like window size and position, decode mode, etc., go right ahead. But for those changes to be made permanent you must use the X button in the title bar of the JTDX window after making the changes. The next time you launch with Slice Master those changes will be restored. For temporary settings changes, just let Slice Master close the JTDX window for you.
--Don
Thank you Don, testing it today.
Seems like it works with HRD settings. I will report if there any other issues.
Apricate your quick reply.
Sergey
@Micheal, Thanks.
No worries. Glad we got the dialogue going!
Im having the same issue what was the fix for the problem0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
